Old 01-30-2018, 11:29 PM   #1
asand1
Drives: 2015 V6 6MT
Airaid MIT, should've went CAI, time for lemonade
So after installing an Elite Engineering catch can I decided to install an Airaid MIT to make the can more accessible and for clearance. I installed the MIT, but found that one clip on the air box was broken off, and the angle of the MIT was off, causing the boot to sit at an angle on the TB.
asand1 is offline   Reply With Quote
Old 01-30-2018, 11:31 PM   #2
asand1
Drives: 2015 V6 6MT
It is time now to take lemons and make some lemonade. I have now ordered a 3.25" aluminum MAF housing and AEM Dryflow cone filter. If you have been bitten by the mod bug and want to mess with your intake just go straight to a good $300 CAI and don't half ass it like me.
So far I am in for.
$127-Airaid MIT
$94--3.25" MAF housing
$56--3.25 AEM Dryflow cone filter
That's already $277, and I still need to make a heat shield. I am playing with a couple of ideas including an aluminum cookie tray and the rubbermaid trash can shield. I will post up pics of my hybrid Airaid MIT/CAI abomination as it progresses.
Here I am getting an idea of room for the pod filter, and planning the heatshield. Of couse I won't really be able to design anything until the filter and maf are installed.
Old 02-02-2018, 02:55 PM   #3
asand1
Drives: 2015 V6 6MT
Installed the MAF adapter and filter today. a little shorter than I had hoped, so its more of a SRI than I would have liked, but oh well. Maybe a 45* elbow between the MIT and MAF to put the filter in the right spot before I fab up some kind of a heat shield.
Old 02-02-2018, 04:47 PM   #4
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
Honestly, you could try getting more pieces and making a long tube intake since you're already here - one that draws from the fender well?
DSX_Camaro is offline   Reply With Quote
Old 02-26-2018, 05:34 PM   #5
asand1
Drives: 2015 V6 6MT
The slow boat from China finally arrived with my 45* 3.5">3.25" silicone elbow. I removed the windshield washer bottle due to interference with the filter. The filter is decently situated now, and using the torque app the intake air is only 10F higher than ambient while cruising between 30MPH and 65.
Old 02-26-2018, 09:41 PM   #6
asand1
Drives: 2015 V6 6MT
I cut out a cardboard template and transferred the pattern to the plastic sheet.
Old 02-26-2018, 09:43 PM   #7
asand1
Drives: 2015 V6 6MT
I then used a combination of aluminum foil, carpet tape, and HVAC ducting tape.
Old 02-27-2018, 11:52 PM   #8
xstuntman
Drives: 2012 Victory Red LFX
Gotta say I'm diggin this so far but then again I'm a backyard engineer myself.
'18 SS wheels, colored matched Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, victory red rotors and calipers, 1/4 window American flags, splash guards, AEM dry panel air filter, Hot Wheels steering wheel and seat covers, Hot Wheels exterior emblems.
xstuntman is offline   Reply With Quote
Old 02-28-2018, 06:53 AM   #9
Vec
Tejas Hillbilly
Vec's Avatar
Drives: 15 SS 2SS/RS LS3M6
i think it looks pretty good !
Navy Vet
Vec is offline   Reply With Quote
Old 02-28-2018, 02:13 PM   #10
BigRed585Lbs
Drives: Sierra and Tahoe
Necessity is a Mother!
Go invent something.
Congrats!
BigRed585Lbs is offline   Reply With Quote
Old 02-28-2018, 06:19 PM   #11
asand1
Drives: 2015 V6 6MT
Thanks for the kind words all. I will be making an acrylic top soon.
Old 02-28-2018, 07:04 PM   #12
Kenny Camaro
Drives: 2013 1LT RS Camaro
Good work. Way to stick with it. Never accept defeat!
Kenny Camaro is offline   Reply With Quote
Old 03-02-2018, 09:37 AM   #13
stlsv6
Drives: 2012 Camaro Ls
Looks good to me.
stlsv6 is offline   Reply With Quote
Old 03-05-2018, 06:39 PM   #14
asand1
Drives: 2015 V6 6MT
Rotofab WW tank is installed and helps the overall look with the intake I think.
