Old 01-31-2018, 08:57 PM   #1
hou30guy
Drives: 2011 convertible 2ss/rs
Supercharger cooling upgrades
What was the 1st cooling upgrade you doing to your car and how muched it helped. I have a 10 rib maggie tvs2300 with od cog and 3.1 sc pulley and 6% ati od balancer, i already have a 1 gallon tank under the hood plus the stock maggie lil reservoir, trying to see what cooling upgrade to do first, im thinking either a 5 to 7 gallon tank in the trunk for extra coolant and just a 1 big fan and or 2 small fans on stock hc, or dual heat exchanger with fans.
Sent from my SM-N950U using Tapatalk
hou30guy is offline   Reply With Quote
Old 01-31-2018, 09:48 PM   #2
QUICRNU
Drives: Z06 wannabe
ZL1 Pump or Varimax pump?
That would be my #1 if I had the smaller Bosch.
Apex Focused
QUICRNU is offline   Reply With Quote
Old 01-31-2018, 09:49 PM   #3
hou30guy
Bought the kit use so im unsure but when i open the reservoir and 1 gallon tank its flowing pretty goooood
Old 01-31-2018, 09:56 PM   #4
hou30guy
Do that look stock
Old 01-31-2018, 10:20 PM   #5
hou30guy
In a tight spot bad pic
Old 01-31-2018, 10:25 PM   #6
2010_camaro
2010_camaro's Avatar
Drives: 2014 Camaro SS
When I was running my LSA I ran straight Engine ICE in it. Was a massive improvement over basic coolant.
MODS 6.0 forged iron block, TH400, B&M shifter, DSS axles & driveshaft, Viking / BMR suspension, Full custom fuel system with cell, Twin 76mm teriyaki tornados on 24lbs.
https://www.instagram.com/whoopa_ss/
2010_camaro is offline   Reply With Quote
Old 01-31-2018, 10:48 PM   #7
hou30guy
Its my daily driver im sure ice will melt after a couple of light to lights on a over driven maggie at 18.5 psi
Old 01-31-2018, 11:43 PM   #8
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
...https://www.engineice.com/
Old 01-31-2018, 11:54 PM   #9
hou30guy
Hmmmm ill look into that thxs
Old 02-01-2018, 12:17 AM   #10
hammdo
'It's an experiment'
hammdo's Avatar
I’ve done a lot on mine. First change is to upgrade to the varimax pump. Myself, I’m running 2 in series.
I have 3 hxs running in parallel — a Ron Davis and 2 in the lower front grill. Then, I installed a roush reservoir.
Hxs:
http://www.camaro5.com/forums/showth...385577&page=76
2nd varimax:
http://www.camaro5.com/forums/showpo...&postcount=757
Roush:
http://www.camaro5.com/forums/showpo...postcount=1752
-Don
747 RWHP 794 RWTQ
Old 02-01-2018, 12:23 AM   #11
hou30guy
I have 3 hxs running in parallel — a Ron Davis and 2 in the lower front grill. Then, I installled a roush reservoir.
Hxs:
2nd varimax:
-Don
-Don
Awesomeeeeeeeeeeeeee
Old 02-01-2018, 12:40 AM   #12
hammdo
hammdo's Avatar
I also run 100% distilled and just enough water wetter to keep the pumps from cavitating....
Helps a lot with cooling...
-Don
747 RWHP 794 RWTQ
Old 02-01-2018, 01:38 AM   #13
Devcon 7
Devcon 7's Avatar
Drives: 15 camaro
I've always had good luck with a bottle of water wetter and distilled water. Would bring my iats down significantly
Devcon 7 is offline   Reply With Quote
Old 02-01-2018, 04:39 AM   #14
hou30guy
Ill drain the coolant and try the destill water and water wetter, but my main focus is battling heat soak due to traffic and light to light runs often
