Old 02-01-2018, 09:38 AM   #1
ejack22
ejack22's Avatar
Drives: 2013 Camaro 1LT Summit White
V6 Brakes to Brembo Brakes
What all is needed to complete this conversion from the small V6 brakes to the bigger Brembo caliper brakes? Looking to buy used so I’m trying to figure out what all is needed? Thanks!
Factory Reproduction ZL1 Wheels (20x10 and 20x11), Nitto Invo (275 and 315), 20 percent tint w/ 5 percent brow, tinted tailights and sidemarkers, gloss black gills and hood spears, ZL1 front bumper, non-RS to RS headlights, 6000k fogs, Anvil carbon fiber rear spoiler, red accent lighting in interior, sunroof, Chevy MyLink, escort passport 9500xi, MRT V2, Vitesse Throttle Controller, Roto-Fab CAI
ejack22 is offline   Reply With Quote
Old 02-01-2018, 09:43 AM   #2
Stewart
Stewart's Avatar
Drives: 2014 Camaro 2SS RS & Ground effects
This may give you some info (I did not read all of it)
http://www.lsxmag.com/tech-stories/b...h-gen-camaros/
Don’t walk in front of me, I may not follow; Don’t walk behind me, I may not lead; Walk beside me, and just be my friend.
MY BUILD LINK: http://www.camaro5.com/forums/showthread.php?t=484260
Stewart is offline   Reply With Quote
Old 02-01-2018, 11:29 AM   #3
Deputy347k9
Deputy347k9's Avatar
Drives: 2014 Ashen Gray Convertible
Look in the for sale section (by members) There is a guy that is selling all four calipers that look to be in mint shape. The price is awesome.
Deputy347k9 is offline   Reply With Quote
Old 02-01-2018, 01:46 PM   #4
gpskinzhut
gpskinzhut's Avatar
Drives: 2020 Corvette Stingray Z51
Install instructions:
https://www.gmpartsgiant.com/installation/23120544.pdf
Parts Breakdown:
*notes:
- You can trim the edge of the rear shields 3/8" instead of outright replacing them if desired. This prevents one from having to R&R the E-brake shoes, bearings, and shields.
- Some owners have opted to not swap the master cylinder. The V8 master can com from an SS, ZL1, or Z28. They're all the same part #.
2020 Corvette 2LT Z51
2017 ZL1 A10: (SOLD) ||
2017 2SS M6: (SOLD) || 2014 2LT Convertible: (SOLD) || 2010 2LT M6 Supercharged:(SOLD) || 1987 IROC-Z 5.0 M5: (SOLD)
gpskinzhut is offline   Reply With Quote
Old 02-01-2018, 01:54 PM   #5
ejack22
ejack22's Avatar
Thanks, everyone! @Stewart @Deputy347k9 @gpskinzhut
Old 02-01-2018, 02:19 PM   #6
Stewart
Stewart's Avatar
You are welcome that is why this forum is so great everyone tries to help out each other.
Old 02-01-2018, 04:15 PM   #7
Deputy347k9
Parts Breakdown:
*notes:
Food for thought.... I was fortunate that I purchased a set of rear shields that usually come with he E-Brake shoes from the salvage yards. You can usually pick them up for $50.00-$60.00 for a set. Replacing the V6 shields was actually quite easy being I didn't have to screw with the E-brake shoes. Just need to make sure you have access to a foot pound torque wrench that will go to the required 199 foot pounds on the new wheel drive shaft nut.
I chose to replace them just to help in reducing the brake dust. My theory is if your going to do the job then take the time and do it correctly. I also changed the master cylinder out, replaced all caliper bolts and the axle nuts being they are torque to yield.
I spent some extra money and maybe 1.5 hours of my time but I now know the system well.
Larry
Old 02-02-2018, 07:47 AM   #8
gpskinzhut
gpskinzhut's Avatar
Larry
Yep, did the same when I did them on my 2010. Though I don't know how you're getting away without having to R&R the e-brake shoes since they mount to the dust shields?
Old 02-02-2018, 07:55 AM   #9
Deputy347k9
Yes the E-brake shoes are mounted to the dust shields, however, all the nuts holding the complete shield in place is accessible from the rear, there was ZERO need to remove the E-brake shoes, other than Chevrolet says to remove them! I DID NOT ever remove the E-Brake shoes from the V6 shields when I removed them. Secondly, the set of SS shields I purchased from a reputable salvage yard came with the E-brake shoes installed, all I did was put them in place and secure them to the proper torque.
Removing and replacing the shoes is probably the toughest part of changing the rear shields.
Old 02-02-2018, 07:59 AM   #10
gpskinzhut
gpskinzhut's Avatar
Ahhh ok you got the plates with all the hardware still on them. Gotcha.
brakes, brembo, caliper, lfx, small
