Old 02-02-2018, 07:01 AM   #1
Slvr-camaro15
Slvr-camaro15's Avatar
Drives: 2017 zl1 ,2010 SS /RS L99
WTB !!! NEED ONLY 1 .rear wheel !!help !!!
Hey guys maybe someone can help me out in the forum . So I took my ride to get the wheels balanced yesterday since the steering wheel was shaking a bit once I hit about 50 + mph . for some reason only one of the rear ones was completely off . No matter how much we tried with the lil weights to balance , It kept showing off numbers . . So ultimately the guy said . Your rim must be bent somewhere very slightly. When we put it on that Lil balancing machine , the wheel had a lil bounce to it . .he said best best is to get another wheel , Tire is still good !! So just wanted to know if anyone has 1 20 inch wheel they looking to get rid off . I have the regular 5 spoke wheels that come with the RS Package .(not in my signature pic).
2017 zl1 - rotofab CAI , PDR , Nav .
2010 camaro SS - Procharger D1 sc (Stage 2 with upgraded intercooler)+ whole lot of other goodies ( too many to list )
Slvr-camaro15 is offline   Reply With Quote
Old 02-02-2018, 01:49 PM   #2
Gossamer
Drives: 2012 Camaro Convertible
front or rear?
I've got a set of rears I bought for 'spares'. Really only need 1.
Gossamer is offline   Reply With Quote
Old 02-02-2018, 01:57 PM   #3
jcabarcas
Drives: 2010 2SS/RS Summit White/Orange Str
He mentioned one of the Rears.
Now, Midnight or Polished ?
jcabarcas is offline   Reply With Quote
Old 02-02-2018, 03:22 PM   #4
Slvr-camaro15
Originally Posted by Gossamer View Post
front or rear?
Yeah rear right one . Apparently it's a little bent . Not visible but the guy at Sears said that thats the only thing that makes sense. Alignment is perfect .all the rest 3 balanced perfectly . This one's keeps saying the weights are heavy or something random like that .
Old 02-02-2018, 03:24 PM   #5
Slvr-camaro15
It doesn't matter the rest of them look like they are regular polished . I plastidip them black .so it doesn't matter. I am not really sure what midnight looks like .b
Old 02-02-2018, 03:26 PM   #6
Slvr-camaro15
Pic attached .
Pardon the appearance. Need to clean it .but here goes
Old 02-03-2018, 09:35 AM   #7
Slvr-camaro15
Hey what's up man
[QUOTE=Gossamer;10064323]front or rear?
I've got a set of rears I bought for 'spares'. Really only need 1.[/QUOTE
Pm'd you . Please respond.
Old 02-05-2018, 12:49 PM   #8
Gossamer
sorry, don't get online during the weekends, only when I'm at work.
Will PM you soon
Old 02-05-2018, 09:13 PM   #9
Turbo_J89
Drives: 2015 BVM Camaro 1LE (2SS/RS)
Did they have the wheel mounted to the balancing machine with the correct metal cone? How much weight was the balancing machine calling for? Was there a lot of weight added during the previous balance? After seeing this bounce on the machine, did you stop the machine and were able to see the bend you didn't pick up on previously?
If you can't see a bend at all without the wheel spinning on that machine I would have the wheel mounted to a balancer at a different shop and make sure your tire isn't structurally falling apart before running out to buy a new wheel.
Turbo_J89 is offline   Reply With Quote
Old 02-05-2018, 09:16 PM   #10
Turbo_J89
Also, wheels aren't perfect and have a heavy spot (some worse than others). The same goes for tires which also have a heavy spot. If it's asking for under 3 ounces of weight and you have verified your tire is structurally sound, you can rotate the tire 180 degrees on the wheel and the machine will ask for much less weight.
