![]() Drives: 2012 Camaro SS Join Date: Apr 2016
Rear End Options For 1000hp
Currently my ss has a procharger f1a making 670whp with 9psi stock motor. The goal is to have engine work done and hit just about 1k hp. I plan on drag racing the car but it will be more of a street car.
My question is what rear end set up to go with and why? The options that I know of are a zl1 conversion, 9in, and Dana strange. |
![]() ![]() ![]() ![]() ![]() Drives: 2013 Camaro SS Turbo Join Date: Apr 2014
If you're on a budget the zl1 can't be beat. You can find complete zl1 rear cradles for around 2000-2500. The only downside is being stuck with either 3.23 or 3.73 gears
Served USN - Atomic Chimp
Drives: 2021 Camaro ZL1 1LE A10 (stock) Join Date: Jul 2012
I've heard the ZL1 is good up to 1kwhp. Not heard of anyone grenading one yet but one person killing a ZL1 axle CV.
If you're really serious, just go 9" and be done with it. I've ran the 3.73 and 3.23 ZL1 diffs and really liked them other than the extra weight. But, hard to beat cast iron for strength. I just had the DSS Proform 9" installed and been driving it around - I can't tell the difference yet, but as soon as Spring gets here, will get to see how it does at the track. The Strange is also a good choice for a few bucks less. So, I'd push for 9" or Strange.
> 2021 Camaro ZL1 1LE A10 > > Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily |
Yea I'm leaning more towards the Dana
Great bang-for-the-buck, IMO. Haven't heard of one breaking on our platform.
#6 |
![]() Drives: 2SS RJT camaro, vortech,684rwhp Join Date: Jun 2009
Pm you
Vortech supercharger 3.15pulley , LPE fuel system, comp cam, double roller, 1 7/8 dyno techs, high flow(see thru) cats, magnaflow 3", Barton short throw, nitto nto5 275 front 315's rear, phadt's lowering springs, sway bars, bushings, trailing arms, diff bushings, dss 9" with 3.90 gears, dss alum drive shaft, BMR adj toe bars, BMR lower control arms, injector dynamics 850's, aeromotive fuel rails, twin disc carbon fiber clutch, tick bleeder
strips painted on, ground effects color matched, wet sanded and buffed, bogarts M &H tires, 11.02@131 |
| Tags |
| 9in, differential, rear end |
