Old 02-09-2018, 07:54 AM   #1
gmcvt
gmcvt's Avatar
Drives: 2019 Camaro 1SS A10
Steering weight/effort
Hey guys, read through quite a few threads but didn't really see this discussed. Just curious about the steering weight/effort on my 2010. It seems pretty heavy to me with only moderate accuracy. I do have the JDP inserts, which certainly helped, but the accompanying weight of the system doesn't seem to be proportional to accuracy. If I'm being honest, I just wish the steering was a bit lighter feeling with not as much effort. In just casual driving, it just isn't very comfortable at all. I'm comparing this with say my brother in laws 5.0 and some Mustangs I've had in the past. Any comments/suggestions? (besides hitting the gym)
"Jesus said to them: I am the way, the truth and the life and no one comes to the Father except through me" John 14:6
2020 Mustang GT M6
2019 Camaro 1SS A10 E85/Pray tuned & ported IM/TB.**SOLD**
2018 Mustang GT A10 Kooks Lt's, E85 & Lund tune*SOLD*
2010 Camaro 2SS/RS M6 Silver- CAI, Bo-body, VRSP-2 cam, Kooks 1 7/8 Lt's w/cats, Magnaflow street CB(15089), QTP ovals, Elite can, Vengeance Racing tune. *SOLD*
gmcvt is offline   Reply With Quote
Old 02-09-2018, 02:42 PM   #2
JusticePete
Drives: Camaro Justice
Which inserts?
Old 02-09-2018, 09:47 PM   #3
KillboyPowerhead
Drives: 2015 Z/22
Carbon fiber wheels
KillboyPowerhead is offline   Reply With Quote
Old 02-10-2018, 07:48 AM   #4
gmcvt
gmcvt's Avatar
Which inserts?
Radius arm
2020 Mustang GT M6
Old 02-11-2018, 10:17 AM   #5
JusticePete
Hmmmm
Alignment specs?
Wheel and Tire sizez?
Old 02-12-2018, 08:20 AM   #6
gmcvt
gmcvt's Avatar
Hmmmm
Alignment specs?
Stock wheel/tire sizes. Just installed a set of the Firestone Indy500's. Love them. We haven't gotten it on the alignment rack just yet but the wear on the old tires was pretty consistent and even.
2020 Mustang GT M6
Old 02-12-2018, 04:23 PM   #7
JusticePete
It ios waaaaaaaay past time I updated the alignment specs on our web page. Have your 5th Gen aligned to my JPSS Street Specs. They will be there i a day, two at the most.
http://www.jpssonline.com/t-camaro-a...fications.aspx
Old 02-13-2018, 10:15 AM   #8
gmcvt
gmcvt's Avatar
Thank you very much!!
2020 Mustang GT M6
Old 02-20-2018, 02:28 PM   #9
gmcvt
gmcvt's Avatar
Just a quick update...the only spec that was out on the front was the left toe and it was at .25(the right was at .04). Tech dialed it back to .10. I've not driven it to see if it had any impact but I'm not expecting much from that. JusticePete, not that this has anything to do with this topic but I'm getting ready to get one of your rear magic bars with necessary hardware. Hopefully combine this with some some cradle bushings to tame the rear of this thing a bit.
2020 Mustang GT M6
Old 02-20-2018, 02:59 PM   #10
JusticePete
Originally Posted by gmcvt View Post
Just a quick update...the only spec that was out on the front was the left toe and it was at .25. Tech dialed it back to .10. I've not driven it to see if it had any impact but I'm not expecting much from that. JusticePete, not that this has anything to do with this topic but I'm getting ready to get one of your rear magic bars with necessary hardware. Hopefully combine this with some some cradle bushings to tame the rear of this things a bit.
What specs did you have them align too?
Old 02-20-2018, 03:06 PM   #11
gmcvt
gmcvt's Avatar
Well, the only thing he did was pull that one side back to 10. He just had a quick second to get the basic data. After I get the rear cradle work done, he is actually going to re-align everything according to your street specs.
2020 Mustang GT M6
Old 02-20-2018, 03:16 PM   #12
JusticePete
Cool
Old 02-20-2018, 03:24 PM   #13
gmcvt
gmcvt's Avatar
What is the drawback to running more aggressive settings? Such as maxing out the front caster? Just harder on the tires I assume?
2020 Mustang GT M6
Old 02-20-2018, 04:07 PM   #14
JusticePete
Caster will not wear the front tires. The 5th Gen is a bit unusual in that we can push the front specs a bit and still get good tire wear. We think that is because it pushes do much, when you reduce the push with a more aggressive alignment you reduce tire wear from pushing. Call it a trade-off.
Toe can go to 0.00 with no additional tire wear.
Camber can go -1.25 with no additional tire wear
Caster -- adding a full degree is pure magic
