![]() ![]() Drives: 2011 convertible 2ss/rs Join Date: Sep 2015
Spark plug for 15-18 psi and the gap?
As the title states Spark plug for 15-18 psi and the gap please
Sent from my SM-N950U using Tapatalk |
![]() Drives: 2014 SS 1LE Join Date: Apr 2014
@ 14 lbs i use br7s @ .028
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
when I used an lsa at 19psi I used br8s @ .018
I was 14.5 with br7es at. 025, just trying to prepare for a retune and swap if needed. I didnt wanna go smaller on the gap on the br7es when technically a br8es with a bigger gap would be better. For some reason i believe there is such a thing as gap too small cant be good. I was thinking br8es and maybe about. 28-.32 for starters
This is on a 408 stroker with 10.1 as compression with a maggie tvs2300. So a lil more cylinder pressure that a stock ls3
#6 |
'It's an experiment'
I asked my tuner, went with these
http://www.camaro5.com/forums/showpo...postcount=1183 416 stroker, 10.5 compression, everything ported so it breathes very well, 2.45/9.17 pulley combo. E85 and 13.5 PSI... -Don
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 Last edited by hammdo; 02-12-2018 at 10:38 AM. |
#7 |
![]() ![]() ![]() ![]() ![]() Drives: 2013 Camaro SS Turbo Join Date: Apr 2014
Br7ef have been used to over 20psi and 1000whp don't need an 8 unless doing more imo. I run them with the gap right out the box just verify they are all the same
#8 |
408 stroker 10 rib supercharged maggie tvs2300 with overdrive cog rear for extra 3 psi, 2.9 sc pulley, and ati balancer 6 %overdrive , 1400cc injectors, fore dual 450s pumps and flex sensor, ls3 ported heads, 3200 stall, btr pds blower stage 3 cam, arh headers with 3" full exhaust, 102mm tb, dual pass heat exchanger with fans and extra 1/2 gal reservoir, im sure im missing other things
#9 |
Hammdo i heard about them r 5671a-8, so what are the difference in them and a br8es, they both is a 8 range
#10 | |
#11 |
That's wrong sorry people need to stop spreading incorrect info
#12 |
Only thing i see different between the 2 are br8es has a 5k ohm resister and the r 5671a-8 dont thats it
![]() Sent from my SM-N950U using Tapatalk |
#13 |
Non resister and geared more for racing. Ryan likes them and he feels they work better with a higher boosted engine (besides less chance of spark blow-out since they are not extended tips).
Since I track my car, running a bigger pulley combo, run at higher RPM (due to road racing), he felt these would give me what I needed for tracking a higher boosted engine. These were tailored to my usage/engine setup. I’ve had 0 issues, no knock/detonation and I do drive on the street a lot. There are other reasons, but those were why we went with those for my application. FYI, no noise interference with the non resistor plugs... -Don
747 RWHP 794 RWTQ
#14 | |
