02-11-2018, 08:08 PM | #1 |
Rust on rotors, sticking when car sits.
Ok, my stock rotors build up surface rust when washed or sitting for long period of time, I have to literally rev the RPMS and pop the cluch (6 speed manual), to get them unstuck, how well do the zinc rotors last for not seeing surface rust. Or whats the best coating to get. TIA
02-11-2018, 08:33 PM | #2 |
Team 913
Drives: '14 ZL1, '15 Jeep GC, ‘22 Ram 2500 Join Date: Apr 2015
Coating wont do anything, it will get wore off with the brake pads and will result in rust on the wear portion of the rotor
All rotors will rust when they sit, never heard of them getting stuck |
02-11-2018, 08:48 PM | #3 |
That's what I thought some rotors say they have rust protection. Brakes getting stuck search came out several others having the same problem. It wasn't to bad when I parked in the garage but this winter I had it parked outside for sometime. I don't drive it much so it will sit for a couple of months, I guess I'm going to have to get out and drive it more.
02-11-2018, 09:40 PM | #4 |
Drives: 2010 camaro ss Join Date: Aug 2016
First thing I would check (and a fast/simple) check would be to see if your brake fluid reservoir is not overfilled?
What I’m getting at is that if there’s too much fluid it can make it difficult for the pistons in the caliber to set back in there respective pots. It would be a logical reason then, for the brake pads to “seize” with the rust forming on the rotors if they can’t settle back. Just my two cents.
2010 camaro
Headers, cat back magnaflow exhaust, performance clutch, K&N edelbrock cold air intake, edelbrock e-force supercharger, aftermarket camshafts. 640hp/610 ft/lb |
02-11-2018, 10:30 PM | #5 |
Thanks, I will check that.
02-12-2018, 05:17 PM | #6 |
Drives: Camaro Justice Join Date: Jun 2007
It isn't the amount of brake fluid. It is just a bit of rust. Iron in the rotors rusts as fast as you wash your car. Let it sit getting wet from weather and there is more rust. No problem. You'll fix it by driving.
02-12-2018, 05:27 PM | #7 |
Drives: 2011 ss Join Date: Sep 2015
I've never heard of having to pop the clutch to get the car moving for oxidized rotors. would it hurt to lift up the car and spin all four wheels to make sure something isn't sticking?
02-13-2018, 02:06 PM | #8 | |
Mods, K&N CAI ,VTC , GM Perf Axleback Exhaust, Elite Eng CC and CSS, GM Strut Tower Brace,Carbon Fiber Anvil Spoiler,ASC T5 Splitter,Gen5diy Foglight kit.
02-13-2018, 02:17 PM | #9 | |
Drives: 2012 M6 ZL1. 2019 Altima.07 FJR1300 Join Date: Nov 2011
02-13-2018, 02:39 PM | #10 |
Drives: 2012 2SS/RS, 1968 SS Join Date: Feb 2012
This sounds normal to me, I deal with the same thing.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS |
02-13-2018, 06:44 PM | #11 | |
