![]() Drives: V6 camaro with straight pipes Join Date: Apr 2017
Does Every V6 Have The Same Trans?
I was looking at my transmission and it’s an aisin ay6 (obviously) but I was wondering if the whole generation had the same manual trans, as I swear I read somewhere that In either 2012 or 2014 there was an upgrade, either in threshold of the current trans or a whole update. Is that true? I was wanting to upgrade mine since my syncros are destroyed
![]() ![]() ![]() ![]() ![]() Drives: 2013 SW 2LT/RS LFX/AY6 Join Date: Feb 2013
No. They are all equally garbage.
| Tags |
| llt camaro, transmission |
