Old 02-14-2018, 07:50 PM   #1
ss/rs/378
ss/rs/378's Avatar
Drives: 2012 ZL1 Camaro Victory Red
M6 to Auto
Has anyone on here converted there m6 to a auto looking for feed back on which auto you went with the cost and the difficulty in doing it, looking at the 4l60e or a turbo 400, also I am at 732rwhp if that matters much? Thanks you all in advance.
2.55 UPPER PULLEY,100MM IDLER PULLEY,160 STAT,PORTED TB,PORTED SNOUT,MSD PLUG WIRES,NKG PLUGS,KENNE BELL EXTERNAL FUEL PUMP,2"KOOKS HEADERS,HIGH FLOW CATS,3"CORSA 60LB DEKA INJECTORS TUNED BY FROST 580RWHP,571RWTQ.
ss/rs/378 is offline   Reply With Quote
Old 03-05-2018, 06:49 AM   #2
christate1
Drives: 2013 Black ZL1 Convertible 6spd
I’ve thought about it there just isn’t a lot of info ☹️
christate1 is offline   Reply With Quote
Old 03-05-2018, 11:48 AM   #3
zman1969
zman1969's Avatar
Drives: 1969 R/S Z28 302 m20 Endura
I spoke with a shop foreman at a local dealer and he has a customer modified m6-auto swap that they have been working on for months and after speaking to him frankly I would advise against this too much electronics involved! I think would be better option would be to get an auto car and swap engines& or parts you have already modded
1969 RS Z/28 302
1969 Firebird LS6-6 speed TA clone
2015 Zl1
zman1969 is offline   Reply With Quote
Old 03-06-2018, 02:26 PM   #4
Ajax2112
Drives: ZL1
Doing a 4L80e or a 400 are not difficult at all. There is a company out of Indiana that sells a complete kit to convert a M6 to a 4L80e. It only a matter of time before I convert mine over.
Ajax2112 is offline   Reply With Quote
Old 03-11-2018, 09:24 AM   #5
christate1
whats their name?
Old 03-11-2018, 11:54 AM   #6
2NASSTY
2NASSTY's Avatar
Drives: 2014 M6 ZL1
Contact Vengeance Racing in Georgia. They have done (3) high HP M6 to TH400 swaps in the past year. All three are now high 9, low 9, and one 8 sec ZL1 I believe.
I personally would never do it. You now have a dedicated drag car IMO with a TH400. You can play with transmission and rear end gear ratios for the 1/2 mile. Then swap them out again for the 1/4 mile. Low cost and high strength swap option is TH400 hands down.
VR can probably do what ever you desire and make it work with 4l80E. I’m sure the price difference is significant vs TH400.
15' Ashen Gray Metallic Z/28
14' Crystal Red Tintcoat ZL1 6M, 9.62 at 150.75 MPH
12' Opulent Blue Metallic CTS-V Sedan, 10.690 at 129.60 MPH - SOLD
06' LeMans Blue Metallic Z06, 11.726 at 127.80 MPH Motor - SOLD.
96' Impala SS LTx, 11.397 at 118.10 MPH Motor, 1st stage 10.526 at 127.46 MPH
2NASSTY is offline   Reply With Quote
Old 03-11-2018, 12:00 PM   #7
O.F.
O.F.'s Avatar
Drives: 2015 BLK/BLK 2SS/RS MN6
Look up CamaroGirl5. She swapped hers recently.
O.F. is offline   Reply With Quote
Old 03-11-2018, 01:05 PM   #8
Blownfogger540
Blownfogger540's Avatar
Drives: 2013 ZL1 416
4l60 is a pos never even consider that
Blownfogger540 is offline   Reply With Quote
Old 03-11-2018, 02:05 PM   #9
Ajax2112
Drives: ZL1
I hope I’m not violated any rules by posting this. I have no affiliation with them nor any personal experience with them. I was referred to them.
http://www.rpmtransmissions.com/page12.html
They offer several options. 4L80, TH400 or powerglide
Old 03-13-2018, 12:08 PM   #10
G Money
G Money's Avatar
Drives: 2013 ZL1, 2016 Denali HD
I have converted over to the TH400 and I am very happy with the results. However you will be limited to where you can drive ie. highways etc. unless you do the Gear Vendor OD. Put me in the #1 spot on the fast list "Unlimited" with just 3 test passes in the 1/4 mile. Should easily run mid 8's with a looser convertor. Like 2NASSTY said contact Vengeance Racing and they can hook you right up......
LSX 427, Twin Precision Turbo's, 64/66. Nitrous Outlet System. Pro EFI Engine Management Systems. Vengeance Racing Built......
G Money is offline   Reply With Quote
Old 03-13-2018, 06:46 PM   #11
white1LE
white1LE's Avatar
Drives: 2013 Camaro ZL1
I looked into doing the swap and the expense is well over $10,000 to install a 6L90 and work exactly like it came that way without any cobbling. so I traded for an identical car with 1000's less miles and perfect condition for a couple $1000. Then swapped my LSX427 from one car to the other and had the turbos installed. 2 years and 20,000 miles later, I couldn't be happier and I'm still on the original transmission at 30,000 miles. These 6l90's are nearly bullet proof. I wanted the car to drive like stock and still race it a few times a year, a th400 would limit that dramatically. All depends on what you want to do with the car in the end. I drive mine a lot!! Good luck
13 ZL1 A6
LSX 427 with AGP Twin Turbos, E85 and Flex Fuel. Built and tuned by ADM Performance
1000rwhp
white1LE is offline   Reply With Quote
Old 03-13-2018, 08:40 PM   #12
miller8907
miller8907's Avatar
Drives: 2014 1SS/RS LS3
Im currently doing a 4l80 swap. Picked up a barely used Jakes stage 3. Still have to purchase other things like standalone computer, shifter, flexplate, driveshaft, trans cooler, and torque converter. In the end I'll have about $5-6000 in it.
2014 1SS/RS LS3 AGP TT, Custom TSP Cam, 4L80E Swap 1/4 mile- 9.53 @ 145mph
miller8907 is offline   Reply With Quote
