02-15-2018, 02:30 PM | #1 |
Drives: 2016 camaro 1ss Join Date: Jan 2016
Fastest M6 and or fastest NA 6th gen in 1/4
So I realized that I want to be number 1 of something.
My options are fastest M6 6th gen and fastest N/A 6th gen. From what I see a 10.4 can do that. Anyone with a 6 speed faster? Anyone NA (no nitrous) faster? I think I can actually make it happen. I did 11.7 with just bolt ons (no E) feathering clutch on radials. My flop will be as follows; 416, pray Cam, tsp heads, pray intake and TB, e85,Centerforce clutch, g force axels and DS, BMR rear suspension, 17inch slicks,and the other normal things. The 6060 may get built after I get my motor back (as I don’t gave a motor currently.) And discuss.
2016 1SS (M6) Kooks headers and exhaust, pray ported MSD/TB, JLT CAI, JLT catch can, TSP heads/VVT-2 cam, E85, Centerfirce clutch, g force axels and DS, most of what BMR makes, blah blah blah
02-15-2018, 08:09 PM | #2 |
Drives: 2010 camaro Join Date: Dec 2017
can't wait for the results. There is only one person so far with a m6 that has ran the best of 11.2 with just e85, cat delete, and msd. I want to see more m6 owners drag their cars and post their times!
02-16-2018, 07:38 AM | #3 |
Drives: 2016 1SS 6speed Join Date: Mar 2016
Ms. Joy’s M6 has gone 10’s but can’t 60’.
My car has gone 11.23@126 with a soft 1.7 60’. If the 2-step does what it should, I’m hoping to whack a 1.4 60’ which should get me well into the 10’s. The biggest issue is getting the 60’ right so we can use the hp.
2016 1SS M6 P1SC Stg II 592rwhp/548rwtq (for now)
GForce Outlaw axles & driveshaft, TSP 2” LT’s, turndowns, RTS S71 drag pack with radials. |
02-16-2018, 07:50 AM | #4 |
Drives: 2017 SS 1LE Mosiac Black Join Date: Nov 2016
I'm still waiting for an M6 H/C NA car to break 10s. Imagine it will happen soon. With a stroker it definitely should not be an issue.
________________________________________________
Frankenstein Engineering Dynamics Stage 1 H/C/E85 536HP/488TQ |
02-19-2018, 01:55 PM | #5 | |
Drives: 2016 CAMARO 2SS Join Date: Apr 2017
The quickest NA 6th gen on motor is a A8. To have the quickest M6 NA you will need to go 11.2 or quicker. I don't see a M6 416 running 10.4 or quicker NA but I say give it hell!! The A8 with Prays H/C packages will soon be in the 9's. I want to say that some of the M6 guys with some power are having issues getting the car to 60ft due to the computer pulling timing under hard acceleration. GPI has messed with some of them so Im told with not much luck. Ms Joys car being one of them Getting a NA M6 car to run quicker then 10.4 is gonna break some drivetrain parts for sure. That's a serious shock to the system and some weight to get moving. Would seriously looking to loops, full suspension and build complete driveline. Mean as clutch too. |
02-19-2018, 08:46 PM | #6 |
My car has gone 11.23@126 with a lazy 1.7 60’.
We’ll see what happens this year with the 2-step and knocking the launch down to 3-3500 rpm. That and the tune is getting some refinement, but more for power then the 60’ right now. I’ll see if he might be interested in getting that part cracked....or I’ll drive over to HPTuners and make them figure it out, since they’re all of 30 minutes from my house.
02-20-2018, 07:33 AM | #7 | |
Don't misunderstand me I'm not hating on the idea of running quicker then 10.4 NA... 60ft will only get you so far and mph will only get you so far... A lot of people think they can power their way to run times but the later the power comes in the drop is less and less no matter the power. For example when I ran my stretched busa.. On motor I would run 9.45-9.50@143-144mph on motor. Turning the 40hp shot right when I shifted to 2nd netted me a 9.42@150.... turning it on at the top of 1st netted me a 9.37@151. Back in 2001 we went 9's with a SBF 347/T5 on spray. Leaving on a 200hp the car would go 10.08@139mph. Hitting the 2nd kit {100hp} right when you shifted to 2nd gear the car would go 9.98@143. The car would average mid to low 1.4's. Changing up the trans with different gearing the car would go a 9.65@139 on the 200hp and get low 1.3 60fts. Over the years I have known a ton of guys that hunt for low 10's and high 9's with the man pedal. Its a challenge for sure. Seen a lot of drivetrain parts break and that's with lighter cars. 3700lbs letting the clutch go for a 1.4 60ft is a hell of a shock to the system. CDFLYER your car has the mph to run 10's. My comments were directed at the OP. I'm a gear banger at heart so I look forward to seeing the progress. |
02-20-2018, 09:03 AM | #8 |
Well ill have slicks, full bmr rear suspension and drive train is all g force. im hoping the stock 6060 will be just fine. If cdflyer has good luck with the two step ill be ordering one also. I think its fairly tangible NA. im just attempting to be 1.4 seconds faster than bolt ons. Im pretty confident I could have had a 10.x pass with just my heads/cam/slicks but I never got a pass in due to issues with valve seals.
Theres a post I just read about the tuning issue. I have also spoke with GPI who is helpful like always. My ace in the hole for this goal will be Pray. Im taking his advice for the set up and the cam specs. Im pretty excited to see the results. Its hard as im trying to beat the a8 guys set up by pray/gpi. Time will tell. Jess, Jesse, and Roho have been awesome helping me out too. Realistically for the 6 speed record im fighting CDflyer and Jess for the win. Im thinking a big nitrous shot on my built bottom end (neither have one as of now) will at least let me say I have the fastest 6 speed at some point. For fastest NA 6 speed 11.2 is the best and I think I would have easily had that already
02-20-2018, 10:43 AM | #9 | |
The current quickest M6's are all power added and the quickest is 10.43@137 on a 200hp shot. With a few making over 600whp on boost running 10.8-10.9@129-130. One being on the 2 step. In theory it all sounds great!! I say give it hell. Personally I have yet to see a 416 make more power then Pray's H/C setup on the stock bottom end. I definitely think you can run in the 10's but I personally don't see you taking the record NA seeing how both records holders where Pray and GPI done cars. And you know Prays will end up in the 9's on motor. But I think you will have a rare beast!! |
02-20-2018, 11:17 AM | #10 | |
Drives: SS 6 speed of course Join Date: Jan 2016
Forged short block, large duration sub .600 lift Cam Motion cam, 7200 RPM fuel cut, Pray Ported Heads, 3.85 pulley D1X, stage II intercooler, DSX secondary low side, DSX E85 sensor, Lingenfelter big bore 2.0 pump, ported front cats, 60608 Borla, LT4 injectors, ZL1 1LE driveshaft and Katech ported TB, ported MSD intake, BTR valvetrain, ARP studs, ProFlow valves, PS4 tires.
02-20-2018, 12:14 PM | #11 |
This is true!!! Area under the curve... oddly enough all the 416 dynos I have seen make about the same hp/torque or less then Pray's H/C packages do from 2500rpm up to his redline. The only place they shine is in the upper rpm's but even then its only for 300rpm or so
02-20-2018, 02:05 PM | #12 |
Before someone pops in and say WTF??? 376 makes stroker numbers!!
Here are 2 LT1 strokers.. 427 and 416.. One from KATECH and the other TSP. Both done on a engine dyno not dyno jet http://www.superchevy.com/how-to/engines-drivetrain/1609-katech-ultimate-427-lt1-naturally-aspirated-performance/ https://www.corvetteforum.com/forums/c7-general-discussion/3382699-stroker-lt1-engine-dyno-graph-inside.html#post1585554092 PRAYS STAGE 1 H/C for the stock convertor http://www.camaro6.com/forums/showthread.php?t=520831 I'm not judging or making any of this up!! Just looking at the numbers. B&R went 8.8 with a 416 F1A and nitrous... Kevin went 8.8 with the 376 and F1A. Just interesting!! This is both Stroker LT's with 15% driveline loss vs Prays through the A8 which is probably 18-20%. 376 does work! Last edited by TEEZYSS; 02-20-2018 at 02:43 PM. |
02-20-2018, 04:12 PM | #13 |
Are those 416s running on E85 or 93?
02-20-2018, 04:44 PM | #14 |
