Old 02-16-2018, 12:40 PM   #1
VRZL113
VRZL113's Avatar
Drives: 2013 VR ZL1, M6
Check your Intercooler Coolant Level!
As the title states, check your intercooler coolant level after the dealer replaces your supercharger for the coupler failure service bulletin. My supercharger was replaced right before I purchased my car in November of 17' (found out after I did a service check), and I never thought to check it. Well, while I was out in the garage tinkering with the car last night, I decided to check it, and low and behold there was no coolant visible at the opening of the filler neck. I purchased some fresh 50/50 Dex-Cool, and started to add coolant. I followed the fill procedure which is by no means difficult (don't let the owners manual scare you), and it took a decent amount of coolant to finally level it off after running the pump a few times to get the air out. No wonder my IAT2's were in the low 120's while cruising on a 40 degree day.
#3257 | 485whp 526wtq | K&N 63-3079 | Gates K080660HD (Green Belt) | ACDelco UPF48R | ZL1 Addons Wicker Bill | Mild2Wild
VRZL113 is offline   Reply With Quote
Old 02-16-2018, 01:38 PM   #2
hammdo
'It's an experiment'
hammdo's Avatar
Excellent post.
Reason I added a bigger reservoir to my LSA conversion:
-Don
747 RWHP 794 RWTQ
Old 02-16-2018, 01:42 PM   #3
VRZL113
VRZL113's Avatar
Originally Posted by hammdo View Post
Excellent post.
-Don
Very nice^
Looks oem.
Old 02-16-2018, 03:02 PM   #4
JB'sZL1
Drives: 2013 ZL1 and 2019 Ram Laramie
Good post.
I will go one further: check your coolant levels once or twice a month.
JB'sZL1 is offline   Reply With Quote
Old 02-16-2018, 03:05 PM   #5
hammdo
hammdo's Avatar
Originally Posted by VRZL113 View Post
Very nice^
Looks oem.
Thanks! It's a 'cough' Mustang Roush Intercooler Reservoir I fabbed the bracket for it...
-Don
747 RWHP 794 RWTQ
Old 02-16-2018, 04:15 PM   #6
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
If your IAT's were that high at cruise then you had insufficient coolant to run the pump as it will shut off by design if there isn't enough coolant. My guess is the dealer which many dont have performance trained techs didnt know that they couldn't just fill an empty SC with out creating pressure or vacuum to eliminate any air so the fluid is vacuumed in.
ZMEnow is offline   Reply With Quote
Old 02-16-2018, 04:48 PM   #7
CamaroSS1675
CamaroSS1675's Avatar
Drives: 2013 Camaro ZL1
Supercharger was replaced on my 13 back in August of 2017. Just checked the coolant. I was about a pint low. Thanks for the heads up.
CamaroSS1675 is offline   Reply With Quote
Old 02-16-2018, 04:50 PM   #8
hammdo
hammdo's Avatar
I vacuum fill mine with the snap on tool. Perfect fill each time...
-Don
747 RWHP 794 RWTQ
Old 02-16-2018, 05:41 PM   #9
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Good reason to have a reservoir- makes it easy to not F it up.
I also have the top readout on my Aeroforce gauge set to IAT2 all the time just to be sure nothing has gone awry.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp // CSP LT's & Ultra Cats // BMR MM // BC Forged KL13
Mods being installed-
oil pump, cam, ported heads, dual in-tank, Goliath and XDI, corn, etc., etc.
RobZL1 is offline   Reply With Quote
Old 02-16-2018, 06:56 PM   #10
hammdo
hammdo's Avatar
Monitor the IATs with mine too...
-Don
747 RWHP 794 RWTQ
Old 02-16-2018, 09:09 PM   #11
incon3037r
GMHIC
incon3037r's Avatar
Drives: 2013 Camaro ZL1/2008 Pontiac G8 GT
External tank and larger HX is definitely the best way to go.
Pontiac G8 GT- ProCharger F-1D, Treadstone TR1235 FMIC, Kooks 1 7/8" LTH,Corsa catback, New Era (228/240) cam, Yella Terra 1.7 Rockers, GMPP LS3 CNC heads, Aeromotive A1000, FAST fuel rails, FIC 1000cc injectors - 762 RWHP/646 LBFT tuned @ 11psi on E85 using HP Tuners
Camaro ZL1- Stainless Works 2" LTH, Corsa catback, RSC PDx cam, ID 1050x injectors, DSX fuel kit, New Era 4.5" intake, BTR springs/pushrods, AFCO heat exchanger, New Era expansion tank, Innovators West balancer, Metco 9.55" lower - 609 RWHP/591 LBFT tuned @ 8psi on 91 octane using HP Tuners
incon3037r is offline   Reply With Quote
Old 02-16-2018, 09:26 PM   #12
hammdo
hammdo's Avatar
I actually have 3 hxs in parallel with 2 varimax pumps in series...
Flow is awesome for sure...
FYI, I’m not a ZL1, just an ADM conversion with an Stroked LSA with mostly GM ZL1, 1LE, and Z/28 parts
-Don
747 RWHP 794 RWTQ
Old 02-17-2018, 10:11 AM   #13
JB'sZL1
That explains the lack of the strut tower brace in your pic.
Old 02-17-2018, 10:32 AM   #14
hammdo
hammdo's Avatar
Yep, had a 1LE bar but, due to a thermal lid spacer to lessen heat soak, had to remove it:
Do a few road courses with it.
Built most of the suspension before all the Z/28 parts became available...
-Don
747 RWHP 794 RWTQ
