02-17-2018, 03:09 PM | #1 |
Drives: 2011 Camaro SS 6sp Join Date: Nov 2016
Fluidampr Crank pulley #760111
I just installed this "balancer"/ crank pulley. It appears to be a two piece unit. The balancer portion is black and has 4 ribs for the AC belt. The accessory drive portion is gray and has 6 ribs.
The supercharger kit im installing requires me to remove the gray portion and install the supplied crank pulley. How the hell do i get the gray portion off?? Ill post pics in a min.
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT 1158whp 1017wtq. 2010 CTS-V A6 - "Stock" SOLD 630whp 658wtq 2024 F-150 RCSB 5.0 4x4 waiting for tunes... |
02-17-2018, 03:12 PM | #2 |
Bolts are out, but it wont budge
02-17-2018, 03:18 PM | #3 |
Drives: 2015 1LE Join Date: Oct 2015
That front pully should just come off with the bolts out, no?
02-17-2018, 03:21 PM | #4 |
i wish. ive been yanking on it for 4 hours.
02-17-2018, 03:26 PM | #5 |
Drives: 2010 SS 2SS M6 Join Date: Aug 2016
looks like the inner hub is interference fit...have you tried going in between the two with some kinda pry bar carefully working around levering up as you go...
or maybe a dead blow carefully wackin the gray pulley again workin around the perimeter... that interference fit will not allow you to pull it apart by hand...good luck OP!
02-17-2018, 03:33 PM | #6 |
im betting the only way it comes off is with a huge 3 jaw puller pushing on the crank bolt.
02-17-2018, 04:47 PM | #7 |
Yup. 3 jaw got it done. Came off with a bang too.
