![]() Drives: 2014 LS Join Date: Apr 2014
Has anyone installed a fuse block?
I'm talking about one such as this.
![]() I have quite a few devices inside my car and i would like to add more. I have already tapped into the fuse box in the side panel but would like to add some extra. If so, where did you put the fuse box? And is it ignition on or always on? Thanks |
![]() ![]() ![]() ![]() Drives: 2013 1SS 1LE Join Date: Jun 2016
I have something similar, mounted it in the area where the cabin filter goes. Very clean set up...
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
'It's an experiment'
Yep:
http://www.camaro5.com/forums/showpo...postcount=1094 But mine is under the hood. Switch powered. -Don
747 RWHP 794 RWTQ
#4 | |
