View Poll Results: Which cam would you pick for N/A now and F/I future
A: 0 0%
B: 0 0%
C: 2 66.67%
D: 1 33.33%
Voters: 3. You may not vote on this poll
Old 02-19-2018, 07:23 PM   #1
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
Which blower cam for N/A and future F/I
O.K. peeps...got another one for those "in the know"...of the 4 cams listed..which one do you feel would make the most N/A keeping in mind future F/I use.
Lot's of peeps have done this so I am hoping again those in the know to chime in on which cam and more importantly why.
let just say hypothetically the car is an M6 with full bolt on's, 3.91's and tuned.
All cams are either off the shelf grinds of well known vendors or maybe a custom grind mixed in...
A----22X/24X .61X"/.59X" 115+5
B----224/240 .604"/.595" 116+5
C----226/242 .626"/.626" 115+4
D----223/231 .629"/.629" 115+?
Old 02-19-2018, 07:44 PM   #2
sixty9fordkiller
Donkey Dick Cam Camaro
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
centrifugal superchargers work really well with NA cams. really well
with that said, i'd get a custom grind cam based off of the positive displacement or centrifugal supercharger i was planning on going with.
assuming its for your 2010 like mine, you will also need to upgrade your fuel system since we didnt get lucky like the 1LE guys. Those come with the ZL1 pump from the factory
Bone Stock
sixty9fordkiller is offline   Reply With Quote
Old 02-19-2018, 07:55 PM   #3
sixty9fordkiller
this car is a nice exmaple.....
Night Fury Cam (One of the most popular/well known off the shelf NA cam)
with an ECS Paxton Centrifugal setup
idling:
not idling
Bone Stock
Old 02-19-2018, 08:05 PM   #4
Bo White
Bo White's Avatar
Im with Monty with this one if going centri.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 02-19-2018, 08:05 PM   #5
Thunder70
Thunder70's Avatar
Drives: 2010 ss camaro
I have the ECS Big Blower Cam runs so strong
Thunder70 is offline   Reply With Quote
Old 02-19-2018, 08:21 PM   #6
Punisher_ATX
Drives: 2010 SS
Our stage 2 supercharger cam gains 60hp consistently over stock cam in N/A applications.
Punisher_ATX is offline   Reply With Quote
Old 02-19-2018, 08:21 PM   #7
sixty9fordkiller
yeah. pretty much
Bone Stock
Old 02-19-2018, 09:13 PM   #8
frankwjr
frankwjr's Avatar
one of them is....Pat G.
Old 02-20-2018, 11:52 AM   #9
Russell James
Russell James's Avatar
Hey, are you guys coming to either Camarofest or LS Fest this year? I stumble across a few cam questions for my toys, will save them up for in person if you'll be at one the Fests again. Always a very helpful display and great people!
Old 02-20-2018, 02:45 PM   #10
lazerlemonta
lazerlemonta's Avatar
Drives: 2010 C6 1LT
None of the above. Maximize your bolt ons, run bottom 11s or high 10s. Then if you decide boost is needed in your life, spec it appropriately with the most current friendly lobes on the planet for your set up from a cam motion core you need a none of the above option Frank LOL
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85
Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE
10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake
Best 1/8 6.80@105.75
Best MPH 134.82
lazerlemonta is offline   Reply With Quote
Old 02-20-2018, 03:32 PM   #11
HorsePowerAddicts
HorsePowerAddicts's Avatar
Drives: LSx Powered
Our S3.3 N/A cam works extremely well with centrifugal superchargers.
Give us a shout, we would be glad to set you up with one of our Cam kits.
HorsePowerAddicts is offline   Reply With Quote
Old 02-20-2018, 06:25 PM   #12
frankwjr
frankwjr's Avatar
High 11's as is, no weight reduction and current mods are my hopes on the 3rd. Now that I have FINALLY pulled my head from my proverbial buttocks and know the hows of launchin..hope to put it to good effect.
Now as for the cam...and supporting valve train...we'll see...peace
Old 02-20-2018, 08:22 PM   #13
Pro-tuned
Angewendet Ingenieur
Pro-tuned's Avatar
Drives: 14 Camaro ZL1
Interesting...
LQ9, Iron Block, Forged internals, 408CI, Jannetty custom cam, TS short block, Whipple, Hardened Jackshaft, PRC 260, 2X3 Dynatech Full Competition, HF Cats, CAI, NW 103, Chee, ID 1300, COPO Breather, MSD, Fore Dual Pump, ultratorque, E85, dual Meth, True Trac, 3:45, 1500hp axle-shafts, DSS CF, BMR, custom Pearl/Candy paint by Jaidah.
Pro-tuned is offline   Reply With Quote
Old 02-21-2018, 10:13 AM   #14
SSBUSDRVR
SSBUSDRVR's Avatar
Drives: '11 2SS/RS IBM/BLK M6
Have a Vengeance Racing Custom Billet Grind here they said would work great with future FI and like you saw in another Thread, just added Boost. Imho and like some of the other guys here just stated, NA Cams can respond well to Centrifugal Chargers. Will soon see how it turns out. Best Wishes.
'11 IBM 2SS/RS Built and Tuned by Vengeance Racing Vengeance PCM
Vengeance Racing Mast Black Label LS7 Headed 416
ProCharger Stage II D1X Race ,Monster Triple,Alky Control Meth Inj, Forgestar F14 Drag Version and a bunch of other blah blah blah.838/688 at 12lbs Street Friendly
SSBUSDRVR is offline   Reply With Quote
