Old 02-21-2018, 04:33 PM   #1
hou30guy
Drives: 2011 convertible 2ss/rs
Meth spray pre blower pros and cons?
Pros and cons on spraying meth at the tb on the 2300 jackshaft maggies
Sent from my SM-N950U using Tapatalk
hou30guy is offline   Reply With Quote
Old 02-21-2018, 06:38 PM   #2
Pro-tuned
Angewendet Ingenieur
Pro-tuned's Avatar
Drives: 14 Camaro ZL1
Cheaper than race gas
Lowers intake temperatures
Can be boost activated
Regulated by nozzle sizes
Easily hidden
Highly corrosive
Have to replace or rebuild pump every couple of years
Eats supercharger bearings if not properly atomized before TB
Don’t forget and let The tank run dry!
LQ9, Iron Block, Forged internals, 408CI, Jannetty custom cam, TS short block, Whipple, Hardened Jackshaft, PRC 260, 2X3 Dynatech Full Competition, HF Cats, CAI, NW 103, Chee, ID 1300, COPO Breather, MSD, Fore Dual Pump, ultratorque, E85, dual Meth, True Trac, 3:45, 1500hp axle-shafts, DSS CF, BMR, custom Pearl/Candy paint by Jaidah.
Pro-tuned is offline   Reply With Quote
Old 02-21-2018, 10:58 PM   #3
BiggFoot
BiggFoot's Avatar
Drives: 2010 Camaro (M6) 1000+ HP SBE
I did it for about 3 years until I made the switch to E85. I had no problems whatsoever.
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam
Brodix BP BR 3 Heads
Kooks LT Headers and full 3" exhaust
Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion
DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears
McLeod RXT Twin HD Clutch & Upgraded Slave
RPM Level VII
TR6060
BMR Drag Suspension Package w/Strange shocks
Carlyle 15" and M/T ET Street R radials
10.1 @ 143 mph 1/4 mile
BiggFoot is offline   Reply With Quote
Old 02-21-2018, 11:06 PM   #4
hou30guy
Dropped the car off today for retune, since i added dual pass hc with fans and 2.9 sc pulley seeing 20 psi now with iat temp 147f bsck to back , was pump only but added flex sensor for e85 and 93. I bet he probably can work around that iat for e85 as long as there is no knock when keep adding timing? Looking for 800to 875 whp, on my 408 stroker setup
Old 02-21-2018, 11:26 PM   #5
hammdo
'It's an experiment'
hammdo's Avatar
Yep, that is how we did mine — raised the temp where timing is pulled since I only race with e85 — taking advantage of the cooling factor since it does not show in iat2.
BTW, post blower spray of meth is better for an SC. The LSA lid upgrade from prometh is an example...
https://prometh.com/collections/nozz...nt=32568697678
-Don
747 RWHP 794 RWTQ
Old 02-21-2018, 11:33 PM   #6
hou30guy
I think he will bypass especially when usimg e85 im just exploring options thats all but i thought our cars dont start pulling timing til 150 plus iat
Old 02-21-2018, 11:42 PM   #7
hammdo
hammdo's Avatar
All in the tune when it starts to pull. I believe the ZL1 SC tune starts pulling at 140. Your tuner decides what best/safe. Can’t wait to see what yours does. Mine is a ‘safe’ tune...
-Don
747 RWHP 794 RWTQ
