Old 02-22-2018, 08:54 PM   #1
hou30guy
Drives: 2011 convertible 2ss/rs
Lfp heat exchanger
I did a lfp dual pass exchanger 389 and orders a dual fan kit from amazon 60 bucks. Just from hpt logging my tempss dropped 40 degree on pulls back to back, i love it. I didnt mount it in the normal spot it normally goes up high. Instead i did it down low and let it rest on the fame support and the brackets sit in between the bumper support
Sent from my SM-N950U using Tapatalk
hou30guy is offline   Reply With Quote
Old 02-23-2018, 12:44 PM   #2
davidscamaro
davidscamaro's Avatar
Drives: 2010 SS/RS M6 BIG cam
What supercharger do you have and how much boost?
40 degree drop is quite good!!
BIG cam ...... 305 45 18 Mickys ...... BMR suspensions
davidscamaro is offline   Reply With Quote
Old 02-23-2018, 12:46 PM   #3
hou30guy
Maggie tvs 2300 at 20 psi, i also swapped the iat sensor for a lsa gm sensor too so the reading is accurate and fast
Old 02-23-2018, 12:50 PM   #4
hou30guy
408 stroker 10.1 compression, maggie jackshaft tvs 2300, rear od cog,front 2.9 sc pulley, btr pds stage 3 blower cam, nw 102mm tb,ls3 ported heads on a 6.0 bored .035 over iron block,1400cc injectors, fore dual pumps with flex sensor, ati od balancer 6%,circle d 3200 stall,18s drag pack,im sure im missing more
Old 02-24-2018, 10:59 AM   #5
davidscamaro
Is that what exchanger the one listed for 07+ gt500?
Old 02-24-2018, 01:19 PM   #6
hou30guy
No the one for the zl1 camaro
