Old 02-28-2018, 11:35 AM   #1
Tommy434
Tommy434's Avatar
Drives: 2014 SS 2010 SS 93 Camaro z28
408 Forged rotating balanced assembly and more
New Manley 408 forged rotating assembly set up for boost balanced by Fowler’s racing engines in columbus Ohio
Manley 4” stroke crank (190024)
Manley 6.125 Rods (14051r-8$
Wiesco pistions w/rings (k445x3)
Wiesco .190 pins (s718)
6.0 steel block
Arp main studs (234-5608)
Block was tumbled but has some surface rust on the out side due to sitting in my shop
Block will need machine work done
3200.00 plus ship and pp
Also have :
2-sets of 317 150.00 each
2 stock cranks 75.00 each
Tons of misc 6.0 parts
Fastest way to reach me is text 614-496-3306 Tommy
Tommy434 is offline   Reply With Quote
Old 02-28-2018, 01:33 PM   #2
Chantro5
Chantro5's Avatar
Drives: 2015 Dodge Challenger R/T Scat Pack
Do you have any stock rods and pistons? Also what condition are the cranks in?
“It is not that I'm so smart. But I stay with the questions much longer.”
― Albert Einstein
Chantro5 is offline   Reply With Quote
Old 02-28-2018, 05:47 PM   #3
Tommy434
Tommy434's Avatar
Just to clarify this is NOT the kit from summit this is for boost with the arp 2000 rod bolts the better gun drilled crank(mains) the thicker pins and wiesco pistons
But it does have the 24 tooth reluctor wheel
Old 02-28-2018, 05:51 PM   #4
Tommy434
Tommy434's Avatar
I’ll have to check on Rods and pistons I had 2 sets I never measured the cranks
6.0, forged, manley, weisco
