Old 11-15-2009, 01:55 AM   #1
joleegp
SS PASHN
joleegp's Avatar
Drives: 2010 RJT Camaro 2SS/RS
Excessive tire wear
Has anyone noticed any excessive tire wear on the inside of the front tires? My camaro has approx. 6000 miles and both front tires seem to wearing faster than expected. Trying to figure out if it is the tire compound, too much negative camber in the factory set up, or a genuine problem.
joleegp is offline   Reply With Quote
Old 11-15-2009, 07:53 AM   #2
Icefsh
Icefsh's Avatar
Drives: CGM 2LT/RS M6
I have noticed excessive wear on all my tires. Only 3000 miles on car and it seems like almost half the tread is gone(20 inch P-Zeros). Have never done a rightous burn out yet and was baffled. Now I have the habit of taking the twisttys pretty fast. Live close to lots of canyons and heck its just plain fun. One of the things I bought this car for.
I believe in my case that the rubber compound that makes my car stick so well in the corners also wears very fast. My tires are wearing even thou.
Icefsh is offline   Reply With Quote
Old 11-15-2009, 09:11 AM   #3
HeavyD
HeavyD's Avatar
Drives: 1SSRS RY L99
Steer tires are probably toed out too much.
HeavyD is offline   Reply With Quote
Old 11-15-2009, 12:16 PM   #4
joleegp
SS PASHN
joleegp's Avatar
I'm up in the central sierras and have 60 miles of twists and turns each day. Sticks like glue and makes the ride way too much fun!!!! Just hoping it is the P-Zeros. They are wearing evenly though. Nice to hear that someone else noticed.
Old 11-15-2009, 03:54 PM   #5
camaro5's Avatar
Drives: X-15 Velocipede
Factory alignments are iffy at best. Get a 4 wheel alignment.
Go from the presence of a foolish man, when thou perceivest not in him the lips of knowledge
General Motors ASEP, A.S. Automotive Technology, Telecommunications Specialist, CISCO Network Engineer
STANDARD DISCLAIMER
camaro5 is furnishing this information "as is". camaro5 does not provide any warranty of the information whatsoever,
whether express, implied, or statutory, including, but not limited to, any warranty of merchantability
or fitness for a particular purpose or any warranty that the contents of the information will be error-free.
camaro5 is offline   Reply With Quote
Old 11-16-2009, 01:06 PM   #6
HTWLSS
Camaro Disciple
HTWLSS's Avatar
Drives: Camaro, Chevelle, Corvette...
Send a message via MSN to HTWLSS
Get your alignment checked under warranty. You can only do it up to 7500 miles for that, so get it in right away or you'll have to pay to have it checked.
How the Disciples help Chevrolet and Being a Camaro Disciple
http://modernclassicsauto.com
'68 Chevelle Malibu Coupe; '67 Chevelle Wagon; '99 Convertible Camaro SS #0069; '07 Z06; '06 Silverado Crew Cab 2500 4x4 dually; '14 Sonic RS Hatchback
HTWLSS is offline   Reply With Quote
Old 11-16-2009, 01:22 PM   #7
HeavyD
HeavyD's Avatar
Always get your car aligned at delivery. I am a alignment tech for heavy trucks and I have aligned literally hundreds of trucks old and new. I can count with only one hand the number of times I have seen a new truck come off the line with a good alignment. They are out pretty much all of the time. You will not feel anything wrong because the vehicle is too new and the tires are in perfect condition. There are actual specs for the alignment of any vehicle and the factory will make the adjustments to get the alignment within "tolerance". Tolerance is the allowable deviation away from the actual spec. During the manufacturing at the alignment station the wheels are adjusted until the results are in the green, thats it! They have no other way of knowing what exactly the results are. Many shops and alignment specialists actually have tighter tolerances than the factory. With the trucks the factory allowable tolerance is actually very sloppy and will cause problems if left at the extreme end of the tolerance range. Plus putting an actual alignment sensor head on the tire is 100 times more accurate than the optical system the factory uses. With independent rear suspension you also have rear toe and camber. Chances are you will have to pay for the alignment, but it is money well spent, plus they aren't that expensive anyway.
Old 11-17-2009, 10:41 AM   #8
joleegp
SS PASHN
joleegp's Avatar
Thanks everyone for the advice. I'm going to start with an alignment tech I trust and if we still see problems head to the dealer.
Old 11-17-2009, 12:50 PM   #9
Toastylicious
My car goes Vrooom.. You?
Toastylicious's Avatar
Drives: 2010 Rally Yellow Camaro LS
So should we just get it aligned anyways, even though we don't see anything wrong?
Toastylicious is offline   Reply With Quote
Old 11-17-2009, 12:53 PM   #10
67 Convertible
67 Convertible's Avatar
Drives: 67 Camaro Convertible
I have 6,000 miles on mine and have noticed no significant wear.
I actually can't wait for my Pierelli summer tires to wear out, so i can put on a decent set of all season radials.
2LT/RS RJT, Blk Rally Stripes, Beige Interior, Sunroof
Placed order at dealer 4/24/09
1100 - 4/28/09
2000 - 5/01/09
2500 - 5/05/09
3000 - 5/05/09
3300 - 5/30/09
3400 - 6/05/09
3800 - 6/18/09
4000 - 6/18/09
4B00 - 6/18/09
4200 - 6/22/09
5000 - 7/01/09
6000 - 7/01/09 It's Home!!
0000 - 7/14/11 Traded in with 24,000 miles. Currently 5th Gen less
67 Convertible is offline   Reply With Quote
Old 11-17-2009, 02:50 PM   #11
HeavyD
HeavyD's Avatar
Chances are there will be out. Since cars in general put on very few miles a years most of the time you will not see any wear starting. Also cars really aren't heavy enough like trucks are to really load a tire. For something like a Camaro I would recommend getting it aligned at delivery, and unless you race, or really torque the suspension, once every couple of years would be great. Alignments are less than $100, go for it!
Old 11-17-2009, 03:06 PM   #12
matt787
matt787's Avatar
Drives: 2LT RS M6 CGM IO interior!
can the dealer do a good job like with laser etc or what other place is recommended? i don't want to take it to firestone or discount tire- they always mess something up or get something greasy
matt787 is offline   Reply With Quote
Old 11-17-2009, 05:23 PM   #13
camaro5's Avatar
They can, just pay for a 4 wheel alignment. Warranty is going to get you a rush job. (set the toe and go)
STANDARD DISCLAIMER
Old 11-17-2009, 05:30 PM   #14
HeavyD
HeavyD's Avatar
I like my local Midas shop. That is true with the warranty! They will rush. The dealer would have the proper specs, I not sure how quickly other shops would get that info.
Tire Sealant Kit - Warranty Issues jbreed Wheels and Tires Talk Sponsored by The Tire Rack 38 09-14-2011 03:18 PM
500.00 per perelli tire not a myth! AVman Wheels and Tires Talk Sponsored by The Tire Rack 51 10-20-2009 04:45 PM
WHAT A NIGHTMARE!!! TAG UR IT 5th Gen Camaro SS LS LT General Discussions 110 09-27-2009 12:25 PM
