![]() Drives: 19’ Camaro SS 1LE Join Date: Nov 2016
Can someone please help me identify this cable tie pictured below?
Of the ones that I know of, there’s one located in the trunk next to the battery, and another one that secures the intake in the engine bay. I’ve looked through several GM/Chevrolet fastener catalogs and can’t seem to locate it. Part number would be awesome. Thanks for any help! |
![]() Drives: 2014 2SS RS, 6 sp man Join Date: Feb 2016
I cut the old gray tie out and just slide a regular tie thru the lock hole.
![]() Drives: 2014 2SS blue Join Date: Jun 2016
Can't help with that specific GM part.
Generically, they are called "stud mount cable ties". Google that and you'll get many sources, sizes, and styles. They replace the old aircraft type of clamp, commonly known as an "adel clamp". Although car makers don't adhere to this, aircraft makers do not use "cable ties, tie wraps" etc. around hot areas such as within engine cowls, because they become brittle with prolonged exposure to heat and fail. Although their are special heat resistant cable ties. The last two pics are of a stud mount cable tie and a stud mount cable tie mounting base. https://www.waytekwire.com/item/2129...tening-System/
![]() Drives: 2012 Camaro Convertible Join Date: Jun 2017
google Hellermann Tyton
Can't 100% say that they make it for GM but a little birdie tells me that they make something real similar. or just google stud mount cable tie |
376 cubic inches of fun
At my dealer, the parts guy would look at blow-ups for you and identify it.
#6 |
Thanks guys.
#7 |
![]() Drives: 2015 1SS / RS NPP Join Date: Apr 2015
Went looking for the same piece a while ago. My local dealers service counter guys all stated they couldn't get the cable tie without ordering the cable it was holding. In my case it was the battery harness.
So, I just kept the nut portion and threaded through a new ziptie as JD555 suggests. |
#8 |
#9 |
Cut the old tie off flush and leave the part it slips threw. Slide a new on in the lock area of the old one.
