Old 03-01-2018, 08:15 AM   #1
1FAST SS
1FAST SS's Avatar
Drives: 2011 Camaro SS
Moving to Colorado
Moving to Colorado in a month and have an inspection question. I currently don't run catalytic converters on my Camaro. Will there be a smog test when I register my Camaro? It also has a tune so no check engine light is on.
2011 Camaro SS Synergy Green
CAI Cold Air Induction, ADM Race Scoop, Apex Washer Bottle Kit, Vengeance Racing Kaotic Cam, DOD/VVT delete and LS3 conversion, American Racing LT Headers, American Racing Headers Off Road pipes, Borla S-Type Catback, FTI Billet Triple Disk 3600 rpm Torque Converter, DSS Aluminium Drive Shaft, AAC Plasma DRL's, Showstopper LED Sidemarkers,Carbon FIber Bow Ties, 35% Window Tint, Llyod's Floor Mats, JBL MS-8 Sound Processor, 2 Alpine PDX-1.600, Alpine PDX-4.100, JL Audio C5-650, JL Audio C5-650x, Alpine T10 Type R Shallow Mount, Stinger Dry Cell Battery
1FAST SS is offline   Reply With Quote
Old 03-08-2018, 02:18 PM   #2
1FAST SS
1FAST SS's Avatar
Nobody?
Old 03-08-2018, 05:52 PM   #3
AG454
I am not "Fast & Furious"
AG454's Avatar
Drives: 2010 Camaro LSX454 1LE
You will have to get emission testing after your car is over seven years old. Then it will be a OBD plug in test for a few years. There are also road side emission testing around the Denver metro area. There are parts of rural Colorado that don't have testing at all. You may eventually encounter a visual test if you don't have cat's. Welcome to the boomtown.
The day I take a bend too fast
Judgement that could be my last
I'll be wiped right off the slate
Don't wait up 'cause I'll be late, I'll be late
AG454 is offline   Reply With Quote
Old 04-26-2018, 09:47 PM   #4
Talladega
Talladega's Avatar
Drives: 2013 Camaro SS
May be too late for you.
What city are you moving to? Like said before some areas of Colorado do not test at all. In the 7 county Denver Metro area they require testing and Cats. Any vehicle 2006 or newer they will do an OBD II test, run a mirror under the car to see and do a pressure test on the gas cap. Cars are exempt from testing for the first 7 years after manufacturing.
They also do roadside testing that if you pass twice within a certain period you are mailed a waiver.
If you are not throwing a check engine light you will likely pass. The people running the stations are pretty quick running the mirror under the vehicle and with car as low as the Camaro I doubt they could see anyways. Worst case you fail a visual inspection, there is no fine or penalty, you simply have to get it fixed to comply. Once it complies you don't have to pay for the second test.
Talladega is offline   Reply With Quote
