Old 11-15-2009, 03:19 PM   #1
markssylver
Drives: 95 bbb impala ss
1000 HP SEVERE DUTY AXLES ????
I installed a set of these axles in my car last week and today i ran the the car up to 120 mph and was getting a vibration from the rear of the car and im thinking its from the axles as i ve had the car up to 140 mph stock and dont recall the vibration also the axles i have are from the Driveline shop any one else with these axles experience this
markssylver is offline   Reply With Quote
Old 11-16-2009, 06:23 PM   #2
markssylver
anybody
Old 11-16-2009, 06:27 PM   #3
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
its possible they are to blame. stock driveshaft?
I piss excellence
and fart awesomeness
Old 11-16-2009, 06:32 PM   #4
markssylver
yes it does still have stock driveshaft also the vibration grows with speed
Old 11-16-2009, 06:33 PM   #5
1320junkie
Drives: The Imperial Army
hmmm interesting
Old 11-16-2009, 07:43 PM   #6
SMPdude
Drives: 2010 Camaros and more
I can tell you that they have been fighting a drive line vibration on the Koni cars and they run the stock axles, but a one piece driveshaft.
SMPdude is offline   Reply With Quote
Old 11-18-2009, 02:15 AM   #7
markssylver
problem fixed
tonight on the way home from work i got on her real hard and started getting vibrations at speeds as low as 30 mph so not being able to sleep i went back towork got her up on the lift trying to figure out were the vibration could be coming from while checking the axles i noticed a lot of slop in the cv joints so i pulled the axles out and put my stockers back in put it all back together and test drove it up 154 and it was smooth as silk no vibrations so now i have to figure out what im going to do with these axles
Old 11-18-2009, 07:19 AM   #8
TC
TC's Avatar
Drives: 2010 VR 2SS-RS
Just installed mine this weekend. Only drove it once and not at that high of speed. I did think it was a little shaky. I have not replaced my front sway bar from drag racing yet either though. Every time I do something to my car I think it takes away from how smooth it was from the factory. I will take her up a little higher today and see what happens. Unfortunately my passenger side CV joint cracked, so I will not be able to do a comparison test.
TC is offline   Reply With Quote
Old 11-18-2009, 08:20 AM   #9
camaro1
camaro1's Avatar
Drives: 550+RWHP 2010 camaro
is there no warranty on these super axles? who is the manufacture. did you even contact them?
Old 11-18-2009, 08:25 AM   #10
2010 2-Tone
Drives: 2010 RY 2SS with Custom Stripes
How much were they? There must be some type of warr on them!!
2010 2-Tone is offline   Reply With Quote
Old 11-18-2009, 08:51 AM   #11
mark_p
Drives: 2010 2SSRS m6
If you have slack the axles are crap. Who made these. I am going to buy some soon and want to know who to avoid.......
mark_p is offline   Reply With Quote
Old 11-18-2009, 08:56 AM   #12
speedster
SST...
speedster's Avatar
Drives: SST Camaro 2010
From what I have been told, most of the "HD, 1000hp" axles sold are made by the same place - the Driveshaft Shop out of NC. You may want to speak with them directly.
Old 11-18-2009, 10:13 AM   #13
ZZcamaro
Drives: 2SS w/ ZZ427 Package!!
Any updates on what the DRiveshaft shop told you?
There are a lot of folks whom want axles, but I am not going to buy ones with this problem. I already have mine lined up from another company, so that is a good thing, but I want to know where not to send my customers if they do not fix this for you!!
ZZcamaro is offline   Reply With Quote
Old 11-18-2009, 11:21 AM   #14
markssylver
the axles are from the driveline shop and they do have a 1 year warranty i just have to call them and get an authorization # to send them back and hopefully they will send a new set without the slop maybe just got a defective set
1,000 HP Extreme Duty Rear Axles and CV Joints Package SpohnPerformance V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 31 02-24-2010 11:50 PM
Gforce Engineering axles and driveshafts coming soon GFORCE1320 V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 13 02-13-2010 12:29 PM
NEW Driveshaft shop High output axles! IPS Brandon V8 and V6 Transmissions / Driveline (6L80 / 6L50 / TR6060 / AY6) 18 09-19-2009 03:38 PM
Hendrix-Engineering hd axles ready to ship Hendrix-Engineering V8 Bolt-Ons & Tunes 8 07-04-2009 11:12 AM
New 4.5 L Duramax Diesel V8 for light duty pickups Scotsman General Automotive + Other Cars Discussion 8 12-01-2008 07:21 PM
