Old 03-08-2018, 05:16 AM   #1
ticowarbird
BOHIC
ticowarbird's Avatar
Drives: 2010 Camaro SS "Enola"
18" front and rear drag setup suggestions?
I've been reading through the forum but still trying to nail down a 17"-18" front skinny and 18" rear drag radial setup that wont break the wallet too too much. I'm thinking Mickey ET Street R's P305/45R18 for the rear, front I want to do a similar height 17" or 18" skinnies. This setup is just for swapping on at the strip. Any suggestions for wheel and tires?
What else can I do to my Camaro?
ticowarbird is offline   Reply With Quote
Old 03-08-2018, 10:43 AM   #2
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
another c5 peep mentioned that Nittos are on sale? if that's the case the 05R is a IMHO very nice tire...when I had my guy mount them we used bead sealer(can't use screws on tubeless)..last season ran them at 17psi and they only slipped once and that was only a 1/4 in...gonna drop to 16 this season...
also consider CTS/CT6 spares rims...lol...18 in and correct bolt pattern...cheaper alternative..front tire would be http://www.mandhtires.com/M-H-Front-...8#.WqFZkOdG3IU
that way don't have to worry about pullin any ABS fuse 'cause the system freaks out when F/R tire height is off too much...good luck OP!
Old 03-14-2018, 04:29 AM   #3
ticowarbird
BOHIC
Just now saw this reply. Pulled the trigger on some 18" MTs front and rear, got some racestar fronts from a member on here, and getting another set of factory reproduction style 41 18x11 for the rear
