Old 03-09-2018, 01:00 PM   #1
mbesman
Great White
mbesman's Avatar
Drives: 2015 Camaro 2SS
Placement Idea for Vitesse Throttle Controller
Thought I'd share the placement of my throttle controller. I placed it under the speedo behind the steering wheel. You can't see it from any location in car. It is real easy to reach if you need to change throttle at any time. Only downside I see is that you can't see what number your on..BUT it is not a problem for me because if you turn the knob all the way down you know your on 0 sop you just have to count each click as you higher the throttle knob. Not very hard to do. I also know if I regularly run at 6 but want to crank it to 9 I just click 3 times..So to sum it up..location is very easy to get to, can't see it from any side, and not seeing the numbers are really no concern IMO.
Share your ideas or location to help those others that want to install the Vitesse. By the way..I love it
mbesman is offline   Reply With Quote
Old 03-09-2018, 01:55 PM   #2
alexlj92
alexlj92's Avatar
Drives: 2014 Black 2SS
I routed mine around and set it over 1 of the 4 gauges in the gauge cluster in front of the shift knob. Sits there perfectly and doesn't move. I never look at those gauges anyway.
alexlj92 is offline   Reply With Quote
Old 03-12-2018, 10:31 AM   #3
mbesman
Great White
mbesman's Avatar
Any pics you can share. Do you see any wiring?
Old 03-12-2018, 10:45 AM   #4
alexlj92
alexlj92's Avatar
I will see if I can snap one.
You only see about 6-8 inches as it comes out of the molding, but I also didn't take to the time to really tuck the wire.
Old 03-12-2018, 11:51 AM   #5
Vec
Tejas Hillbilly
Vec's Avatar
Drives: 15 SS 2SS/RS LS3M6
Talking
6.0MPG...lol
Navy Vet
Vec is offline   Reply With Quote
Old 03-13-2018, 12:34 PM   #6
mbesman
Great White
mbesman's Avatar
Not sure if you mean 6.0 mpg with Vitesse throttled at 9 but I average 16-18 with it at 9. Once you get used to it you learn how to drive smoothly with it at 9. I've had it at 5 also which is still very good but I like the option to punch it if needed
Now I see what you mean..lol...that 6.0 mpg was when I reset the MPG and did a quick 0-60 test run. But my normal daily drive with it a 9 gives me 16-18 mpg.
Old 09-27-2019, 01:55 PM   #7
Greencamaro1234
Drives: 2011 Camaro LS
I think that’s a good spot for it above the steering wheel,I just ordered one yesterday,and think that’s where I’ll put mine,but I always tilt mine up and down,so doesn’t interfere with raising it up and down,and have you had any problems with it,as for codes,or stabiltrax on and off.
Greencamaro1234 is offline   Reply With Quote
Old 09-27-2019, 01:57 PM   #8
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
Trash can.
Best place for one. lol
lol i know this is gonna be deleted.
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads.
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
Old 09-27-2019, 02:33 PM   #9
KillboyPowerhead
Drives: 2015 Z/22
I used the little inset part of the dash directly to the right of the steering wheel, although some models have buttons there (I think 1LS, 1LT and 1SS don't and 2LS, 2LT and 2SS do?). Can't even see it from the drivers seat and is a pretty clean install with double-sided tape; fits nice and snug.
KillboyPowerhead is offline   Reply With Quote
Old 09-27-2019, 02:55 PM   #10
spyderbuddy
spyderbuddy's Avatar
Top left in Glove box
2024 Camaro/Panther Emblem,Hot Wheels Emblems, Hot Wheels Door Sills and Floor Mats, Morimoto Fog Lights, PCP Hideaway Headlight Covers, BBK Headers & High Flow Cats, ZL1 Add-ons Wicker Bill, TL1/ZL1 Hood Insert, Gen5 DIY Frameless Mirror, ABL Dash Lighting & My link Navigation, Blacked out Rear Bowtie, all Sylvania led Turn Signals, Ceramic Window Tint By Nicks, MBRP Exhaust tips, GEN5 DIY Virginia Legal DRL Harness, Painted Brake Calipers, Vittesse Throttle Controller & Paddle Shifter Heritage Grill, Manual Shifter Boot, CNC Throttle Body, Trifecta Tune, Trunk Black out and Side Grills,
Old 09-29-2019, 05:49 AM   #11
Tarendor
Tarendor's Avatar
Drives: 2012 camaro 2ss rs L99
You can see where I put mine, I have changed the shifter but the controller is still in that spot.
2012 2SS/RS, L99, no cats/mufflers, Ported intake manifold, fuel rail upgrade, ID1050x injectors, Vmax throttle body, 25% UDP, GPI DOD delete, GPI SS3, GPI cnc heads, GPI – 5/16″ Hardened Pushrods, BTR trunion upgrade, BTR .660 springs, pcv revamp w/dual catch cans, Circle D 3800, full BMR suspension & bushings. ZL1 fuel pump, HPT programmed fpcm. JMS bap, Snow VC-50 methanol setup. custom 4gal methonal tank, vs7875 turbo, FMIC, precision 46mm WG, 50mm BOV, 3bar map, SJM line lock, Innovate SCG-1, Hurst shifter with tap shift mod, ×2 Holley 14" fans Diy E85, Diy auxiliary pump
Tarendor is offline   Reply With Quote
Old 09-29-2019, 02:41 PM   #12
Greencamaro1234
I hadn’t received mine yet,but where do you keep yours at.
Old 09-29-2019, 04:13 PM   #13
lemontwist
lemontwist's Avatar
Drives: 12 2SS/RS L99,11 2SS/RS LS3totaled
the console area is best imo that is where mine is easy to use on the fly i don't want to reach thru my steering wheel to change the setting when i'm rolling.
1 small piece of 2 sided tape and its super secure the actual controller and associated wiring are inside the console installation took all of 10 min.
lemontwist is offline   Reply With Quote
