Old 03-09-2018, 02:57 PM   #1
SS Brandon
Drives: 2018 Camaro ZL1 1LE
Fast EZ-EFI 2.0 (For Sale) - NEW in Box
SOLD !!!
FAST EZ-EFI 2.0 GM LS Self-Tuning Engine Control System
This kit was purchased and never used. I planned to do an LS Swap. Completely Brand New and still in sealed package. Prices includes shipping and insurance to continental US. PM, email, or text for more info.
33 Feedback Rating on LS1Tech
1452 eBay Feedback Rating
Brandon
630-209-1860
jbrandon3@yahoo.com
Fast EZ-EFI 2.0 - Complete (New in Factory Sealed Box)
Part Number: FST 30405-KIT
$1150 Shipped!!! - SOLD -
Info
Easy LS-Engine Swaps; No Complicated OE-Harness Re-Working or Costly PCM-Tuning
FAST engineers have developed the simplest plug-and-play, self tuning engine control system on the market for the LS series of engines. The FAST EZ-EFI 2.0 LS Self Tuning Engine Control Kit is the easiest way to get your LS transplant up and running without the complex PCM flashing and harness reworking required with the stock unit. This kit features all of the advantages of the award-winning EZ-EFI 2.0 ECU, plus it includes the EZ-LS Ignition Controller and uses stock or aftermarket LS injectors, sensors and coil packs.
Advanced Color-Touchscreen Hand-Held Can Replace Tach & Most Gauges
Each FAST EZ-EFI 2.0 system utilizes an easy-to-use interface through the included touch screen hand-held and doesnt require a laptop or tuning experience. After initial setup, the hand-held can be used as a digital dash with the included suction cup window mount. The EZ-EFI 2.0 system actually tunes itself as the user drives, and because it keeps tuning, future engine upgrades are a breeze, meaning that expensive trips to the shop for simple tune changes are a thing of the past. A purpose-built, OEM-quality wiring harness is included in the kit as well. It features a clean, mesh wrapping that dramatically improves engine aesthetics over the factory harness. And with the included FAST EZ-LS Ignition Controller, the user can easily get running or has the option to adjust timing. This multi-port installation kit is compatible will all LS-based car and truck engines and is designed and engineered by FAST. The EZ-EFI 2.0 LS Self Tuning Engine Control Kit is made in the USA, features a limited lifetime warranty and is backed by the industrys most extensive technical support team. If converting from carburetor, requires fuel system to be purchased seperately.
  • Self tuning EZ-EFI gets you up & running quick & EZ; No laptop or tuning knowledge necessary
  • EZ-LS Ignition Controller offers no tuning quick setup option as well as custom tuning via hand-held
  • Hand-held displays up to 20 live-data readings/sensors; various dash display options
  • Limited Lifetime Warranty & backed by the industry’s most extensive tech support team
  • Modern, mesh-wrapped wiring harness replaces ugly, complicated stock harness
  • 100% designed & engineered in house by FAST staff
  • Uses OE/stock-style, LS sensors, ignition, & injectors
  • Hand-held start-up gauge screen is user selectable
SS Brandon is offline   Reply With Quote
Old 05-02-2018, 09:03 AM   #2
SS Brandon
Bump for Price Drop!!
$1150 Shipped
Text me at 630-209-1860
Brandon
Old 05-02-2018, 09:37 PM   #3
SS Brandon
SOLD
ecu tuning, efi, ez-efi 2.0, fast, ls3
