Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Members Area > Ask the Camaro Team
Old 03-13-2018, 08:39 PM   #1
CruzySS
CruzySS's Avatar
Drives: 2016 Camaro 2ss
Throttle cable
What was the purpose of going away from cable throttling? A cable throttle system seems more reliable and less chance to have electrical issues. No potential of lag from inputting throttle through the computer. Will we see this system again?
CruzySS is offline   Reply With Quote
Old 03-13-2018, 10:11 PM   #2
Matos1LE
Drives: SS 1LE
The only advantage I see is that it allows them to tailor the throttle behavior in different modes. I heavily doubt they will ever return to a good ole' fashioned cable.
Matos1LE is offline   Reply With Quote
Old 03-14-2018, 06:31 AM   #3
Gen6 softtop
Drives: Hyper blue 1ss convertible 6 sp
they've been gone it going away for a decade or so, doubt their coming back
Gen6 softtop is offline   Reply With Quote
Old 03-14-2018, 07:30 AM   #4
Norm Peterson
corner barstool sitter
Norm Peterson's Avatar
Drives: 08 Mustang GT, 19 WRX
Hmmm . . .
Traction control and stability control
Emission control
No-lift shifting
Launch control
Automatic rev-matching on downshifts
Automatic cruise control
AT shifting gets the same commanded throttle information that the engine's fueling and ignition does
Wires are less demanding of space as far as fitting their physical routing in with everything else is concerned
Wires can go through the firewall through a sealed connector, cables need a real hole
As mentioned, different throttle mappings for different drive modes.
It's extremely doubtful we'll ever see any more OE cable controlled throttles on anything, let alone on regular-production cars with a VIN that are intended for street use.
Norm
'08 GT coupe 5M (the occasional track toy)
'19 WRX 6M (the family sedan . . . seriously)
Norm Peterson is offline   Reply With Quote
Old 03-14-2018, 08:49 AM   #5
shaffe
Drives: 21 Bronco
I do miss cable controlled throttles. I wish they could just get rid of the delay. In my 04 Mustang, I could cut killer lights. Never came close to getting the same kind of R/T in my 07 with the drive by wire
Originally Posted by 72MachOne99GT View Post
Lets keep it simple. ..
it has more power...its available power is like a set kof double Ds (no matter where your face is... theyre everywhere) it has the suspension to mame it matter...(
shaffe is offline   Reply With Quote
Old 03-14-2018, 12:02 PM   #6
vtirocz
vtirocz's Avatar
Drives: 2017 Camaro 1SS M6
Originally Posted by Norm Peterson View Post
Hmmm . . .
Emission control
No-lift shifting
Launch control
Norm
Good list. I’d only add that it can enable a fuel economy benefit also with the ability to motor (0 fueling) with the throttle blade open and potentially stay at 0 fueling longer.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph
vtirocz is offline   Reply With Quote
Old 03-17-2018, 07:35 AM   #7
WhyUMad1LE
Drives: 17 SS 1LE
Is there a new car today that still comes with a throttle cable?
WhyUMad1LE is offline   Reply With Quote
Old 03-18-2018, 02:31 AM   #8
DGthe3
Moderator.ca
DGthe3's Avatar
Drives: 05 Grand Am GT
Generally speaking, electronic systems are more reliable than their mechanical equivalents (fewer moving parts). Difference is, if things happen to go wrong its usually easier to repair a mechanical system.
For example, how often have you had to adjust your electronic fuel injection vs jamming a screwdriver into your carb to get it to open?
99.99% of people would rather have fewer hassles than the option to fix things themselves. Because if something rarely fails, you rarely have to fix it. Hence, more electronics in cars.
........and HE WOULD KNOW!!!!
Camaro Fest sub-forum
Old 04-04-2018, 07:44 PM   #9
Boost Creep
Boost Creep's Avatar
Drives: '18 1SS 1LE
One of the main reasons manufactures got away from throttle cables is noise transmission.
The throttle cable brought engine noises, both good and bad right into the cabin, right to the driver. The rest of the advantages were just a benefit as technology progressed.
Boost Creep is offline   Reply With Quote
Old 04-04-2018, 07:46 PM   #10
ninetres
ninetres's Avatar
Drives: Crush ZLE M6 | 2000 Corvette FRC
If that was a test question I would have marked it “FALSE” lol. Who knew?!
ninetres is offline   Reply With Quote
Old 04-05-2018, 08:58 AM   #11
MGD
MGD's Avatar
Drives: 16 Camaro SS
If that is the case, then why would they remove the throttle cable to get rid of the noise and use a sound tube to bring it right back?
Interior: Adrenaline Red. SS/2SS, M6, NPP, Sun Roof, 8" Nav. Black 5 Spoke Wheels.
MGD is offline   Reply With Quote
Old 04-05-2018, 09:38 AM   #12
DGthe3
Moderator.ca
DGthe3's Avatar
Not that I buy the claim that they eliminated mechanical throttle cables because of noise but IF its true its because not all sounds are equally desirable.
Sound tubes are there specifically to pipe in induction sounds from the intake. Lots of people like induction noises. Personally, I've never cared. But I know its a thing that others like. The throttle cable, presumably, either transmits general engine vibration or the 'random' mechanical noise that an operating engine makes. And those sounds probably aren't as pleasant to most people as induction sounds.
Old 04-05-2018, 11:24 AM   #13
Boost Creep
Drives: '18 1SS 1LE
Because engine growl is a good noise people like, and the ticking of injectors and valves are sounds no one likes.
Old 04-05-2018, 06:14 PM   #14
rebelyell22
rebelyell22's Avatar
Drives: 2011 SIM 2SS/RS LS3
Get a tune
2011 2SS/RS built 8/24/10
rebelyell22 is offline   Reply With Quote
