![]() Drives: 2013 ZL-1 Join Date: Apr 2017
anyone do a cheap truck manifold single turbo setup ?
I want to do such a setup, I even thought of plate mounting the motor to make lots of room around the block for piping.
![]() Drives: 2010 SS Join Date: Jun 2015
Im running one.
Running the Trick Performance kit. Needed to relocate ABS a smaller turbo would even clear the hood.
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
I'm doing one as well but my turbo is in the same position as stangkilrs camaro was
![]() Drives: 14 SS 80mm Snail Join Date: Feb 2018
I am. Flipped up, works like a charm. Gotta brand new set of eBay forward up headers just sitting around now if anyone is interested in them, brand new cheap.
