Old 03-15-2018, 09:55 PM   #1
go_go_gadget88
go_go_gadget88's Avatar
Drives: 2010 Camaro 2SS/RS ABM 6M
Oil Cooler delete questions
Well, I started tearing back down some to inspect things with my build. When I went to jack the car up, I noticed a small puddle of coolant underneath. After some tracing, it looks like it's coming out the large "plug" on the drivers side where the oil cooler line goes into the block.
Since I have fluids out, it seems like a good time to go ahead and just delete the whole thing. Is this all I need (full delete)?
http://www.improvedracing.com/coolin...ductsearchusen
And then, I couldn't find from a search. What size socket is needed to take that factory plug out of the block? Looks pretty big.
And for the new plug that comes in the kit, what is needed to put that in? I am guessing I have neither of these tools.
Thanks in advance!
2010 ABM 2SS/RS LS3 6 Speed -- Rotofab CAI | Speed Engineering 1 7/8" Longtubes w/ cat Delete | Magnaflow competition catback | TSP 231/246 cam| TSP/PAC .660" Spring Kit | TSP CNC Ported Heads | Bo White PTB | GPI Ported/RM Intake | 3.91's | BC Catch Can | MGW Shifter | BMR 1" Drop Springs | BMR Trailing arms/Toe Rods/Rear UCA Bushings | Pegasus Subframe Mounts
go_go_gadget88 is offline   Reply With Quote
Old 03-15-2018, 11:48 PM   #2
Synner
Drives: cars
I believe it was 22mm. I used a motorcycle axle removal tool or you can find some giant allen wrenches by googling.
Old 03-16-2018, 03:53 AM   #3
Pro-tuned
Angewendet Ingenieur
Pro-tuned's Avatar
Drives: 14 Camaro ZL1
What’s the plan after deletion?
LQ9, Iron Block, Forged internals, 408CI, Jannetty custom cam, TS short block, Whipple, Hardened Jackshaft, PRC 260, 2X3 Dynatech Full Competition, HF Cats, CAI, NW 103, Chee, ID 1300, COPO Breather, MSD, Fore Dual Pump, ultratorque, E85, dual Meth, True Trac, 3:45, 1500hp axle-shafts, DSS CF, BMR, custom Pearl/Candy paint by Jaidah.
Pro-tuned is offline   Reply With Quote
Old 03-16-2018, 04:44 AM   #4
Bo White
Bo White's Avatar
Probably leaving it off.
Mine has been deleted for 70k miles now.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 03-16-2018, 07:13 AM   #5
go_go_gadget88
Correct. If the thing is just gonna leak I'll just take it all off and eliminate the possibility.
Since you've done this Bo, do you remember the sizes of the factory plug, Or the new one?
Old 03-16-2018, 07:35 AM   #6
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
the oil cooler/heater get's the motor up to temp faster...mostly for emmision's but a motor that warms up quickly does ultimately have less wear...
my plug has been weepin for a while now...traced it after gettin a wiff one day...my understanding they got cross threaded at the plant...
Bo - how did the delete affect your regular drivin temps..if at all?
Old 03-16-2018, 07:51 AM   #7
Bo White
Bo White's Avatar
Takes longer for oil temps to get up and it's about 240ish on the interstate.
Oil temps between 230-260* are ideal.
Totalled:
Old 03-16-2018, 07:53 AM   #8
lazerlemonta
lazerlemonta's Avatar
Drives: 2010 C6 1LT
If your not road course racing the cooler is just something else to go bad imo. I have not seen oil temps much more the 220-240. Hell real drag racers back in the day would use 3 quarts of oil lol now we have improved racing scrapers and baffles..... much better option
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85
Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE
10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake
Best 1/8 6.80@105.75
Best MPH 134.82
lazerlemonta is offline   Reply With Quote
Old 03-16-2018, 07:54 AM   #9
TXM62SS
TXM62SS's Avatar
Drives: 2012 2SS/RS LS3
Got rid of mine about 3 years ago. No issues at all.
Victory Red 2012 2SS/RS LS3 Camaro
Pat G. Spec Cam from Cam Motion 228/236 .599/.599 112+2LSA
Kooks 1-7/8" LTs w/ Cats
Roto-Fab, Bo White TB, Borla Touring Catback
3.91 1LE Gears, MGW
Tuned by Pat G
TXM62SS is offline   Reply With Quote
Old 03-16-2018, 08:00 AM   #10
Bo White
Bo White's Avatar
Agreed on road racing. Extended high rpm racing will tax oil.
Totalled:
Old 03-16-2018, 08:01 AM   #11
Bo White
Bo White's Avatar
http://www.camaro5.com/forums/showthread.php?t=390453
Totalled:
Old 03-16-2018, 08:09 AM   #12
xc_SS/RS
Drives: 2010 Camaro SS/RS
how likely is it that the plug is crossthreaded?
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 03-16-2018, 08:51 AM   #13
go_go_gadget88
Since you have done this, do you know what tools I need for those large plugs? And does the cooler come out fine with the pan and everything still bolted in place?
Yeah I have seen this. That's one of the posts about it that made me decide to just delete. Not seeing tool sizes listed in that thread though?
Well, I'm sure it has been in there from the factory. But as mentioned above, I guess the factory crossthreaded some of them? I had no leaks before my cam swap, and didn't think I had messed with this any to cause a leak.
Old 03-16-2018, 09:22 AM   #14
Bildo
Bildo's Avatar
I left mine on the LS3 when I sold it, just blocked off the radiator bung with a vacuum cap and a hose clamp. New block already had a block off plate above the oil filter housing.
2012 2SS M6, ERL Superdeck 6 427, PRC 255 Heads, Procharger F1A w/ 3.85 pulley, 1300hp intercooler, Squash Dual 450lph, E85, ID1700, RXT Clutch, DSS 1pc driveshaft, GForce axles, Eaton Detroit Trutrac, a bunch of other crap I don't feel like typing.
Bildo is offline   Reply With Quote
