![]() Drives: 2012 Camaro SS Join Date: Apr 2016
WOT Box
So I just installed my n2mb wot box and it works great. Without any adjustments the 2 step popping is very rapid. Does anyone know what PID values to use for slower louder pops? This is just a personal preference.
Angewendet Ingenieur
Drives: 14 Camaro ZL1 Join Date: Apr 2015
This is a result of timing delays, you would be better served to move it to the tuning section.
LQ9, Iron Block, Forged internals, 408CI, Jannetty custom cam, TS short block, Whipple, Hardened Jackshaft, PRC 260, 2X3 Dynatech Full Competition, HF Cats, CAI, NW 103, Chee, ID 1300, COPO Breather, MSD, Fore Dual Pump, ultratorque, E85, dual Meth, True Trac, 3:45, 1500hp axle-shafts, DSS CF, BMR, custom Pearl/Candy paint by Jaidah. |
![]() ![]() ![]() ![]() ![]() Drives: 2013 Camaro SS Turbo Join Date: Apr 2014
Cant help with the question but Ive been looking to put one in, do you have a wiring diagram how you wired it up?
I don't have a diagram but you can message me on Instagram @nick_glodava add I can help you out with whatever you need.
Served USN - Atomic Chimp
Drives: 2021 Camaro ZL1 1LE A10 (stock) Join Date: Jul 2012
n2mb WOT box cuts ignition to hold RPMs and build boost with the throttle wide open. No timing retard is used with this controller. You can, however, drop some timing in the main timing tables in the areas of the load/rpms. This will likely affect normal driving. What some do is make a simple anti-lag switch using the IAT MAF and -40*F table for timing modifier.
Attached is the Camaro wiring schematics that you'll have to use to figure out what wires to tap into. Maybe GHOSST2012 took notes installing his and would help tell you where he tapped in to.
> 2021 Camaro ZL1 1LE A10 > > Past Builds: 2013 Twin-Turbo LSX434 M6 - 1,359rwhp daily |
#6 |
I am currently assisting two other people with this install. If anyone needs help feel free to message me on Instagram @nick_glodava
#7 |
I was told by Jon at n2mb that the solution to my preference is to change the number of cylinders I have selected in the software. He said try changing it to 6, 4, or 2. I will try tomorrow.
#8 |
![]() Drives: 2010 SS/RS LS3 M6 Join Date: Apr 2011
I would like to hear if this works, I disabled the 2 step on mines because of that.
#9 |
Have you tested this theory out yet?
Cai intake and a few other mods😎
| Tags |
| 2step, n2mb, wot box |
