03-16-2018, 10:53 AM | #1 |
Drives: 2010 Chevrolet Camaro 2LT Join Date: Mar 2017
2010 Camaro 2LT Catalytic converters
Hi guys,
I am having a CEL and it's diagnosed and found to be a failed Catalytic Converter. How Many Catalytic converters does a 2010 Camaro have??? Mine has a V6 engine.. Cheers, Peters |
03-16-2018, 11:06 AM | #2 |
Drives: 2015 Z/22 Join Date: Aug 2015
Four cats, two per side.
03-16-2018, 02:34 PM | #3 |
having FUN now 13.66@101
03-19-2018, 06:44 AM | #4 |
Drives: 2012 V6 Camaro 2010 Camaro SS Join Date: Jun 2010
How long do the stock GM catalytic converters generally last before they fail and need to be replaced?
Mr. Clean
03-19-2018, 09:11 AM | #5 |
Drives: 2012 Victory Red LFX Join Date: Dec 2012
I think they are under warranty for 80K/8 years.
2018 SS wheels, red Heritage grille, actual driving lights, ZL1 strut tower brace, GM Performance billet aluminum fuel door, front grille Bowtie delete, painted red rotors and calipers, 1/4 window American Flags, splash guards, AEM dry panel air filter.
