Old 03-18-2018, 09:54 AM   #1
geminisbro
invisible motion man
geminisbro's Avatar
Drives: 2011 Camaro 2LS
Smile Is 1st trans. fluid change OK at 100K?
So I made a mistake, and while I followed all the other service recommendations, I didn't get the transmission fluid flushed at 50K.
Now (its at 100046 miles) I take it to the local auto shop and they say they won't do it because its 'dangerous', but didn't get a very good explanation on why....here's a footnote included on the quote from the shop:
_________
CAUTION: High Mileage Vehicles: If you have not had your transmission fluid flushed in accordance of your vehicle manufacturer recommendations, this service may cause damage.
_________
So I called the Chevy Dealer and they said they could do it because they have a 'special machine' that will be safe to use...my father seemed to think this may be suspect, but the folks there do specialize in Chevy.
What should I do? Chevy Dealer or leave it alone?
Thanks in advance!
⎷⎛ Festina lente? Ocius quam ventus. ⎷⎛
geminisbro is offline   Reply With Quote
Old 03-19-2018, 09:49 AM   #2
polizzio
polizzio's Avatar
Drives: 2012 1LT SIM Camaro
I'm not so sure I'd do the flush thing, but I'd surely have a shop drop the pan and replace the filter. Then makeup with new fluid to correct level. Just leaving it alone at this point and driving on is foolish. Normal auto tranny service recommendation is @ 97k in owners manual.
I have a 2012 V6 auto with ~ 58k mileage. I want to have the above done any time now. I did quite a bit of reading on line about flushing, and a lot of comments out there are not good.
We had another thread on the similar discussion, but never got a lot of input. Seems many just driving on with the automatics. I was hoping for more discussion, more input/experiences from owners here. Many of the 2010/2011s are way over 100k miles now.
polizzio is offline   Reply With Quote
Old 03-19-2018, 09:56 AM   #3
polizzio
polizzio's Avatar
AC Delco V6 auto tranny filter $28 at rock auto.
https://www.rockauto.com/en/moreinfo...sn=586&jsn=586
Old 03-19-2018, 03:58 PM   #4
DonM
Camaro #4
DonM's Avatar
Drives: 2017-Hyper Blue Metallic-2LTmanual
If I remember this right, leaving the fluid in an auto trans too long can cause varnish build up on the parts & seals. Then when a flush is done, the cleaners in the new fluid 'clean off' all the built up varnish leaving you with increased clearances on moving parts and possibly leaky gaskets.
I had an old 1975 Ford Pinto with over 70,000 miles when I did a drain, filter change and refill, not even a flush and after that once the trans got hot, I lost 3rd and reverse gears. Granted your car is about 40 years newer than my old Pinto, but you never know.
Don M
Supercharged LGX + 6 speed manual = FUN!!
DonM is offline   Reply With Quote
Old 03-19-2018, 04:49 PM   #5
ChibiBlackSheep
ChibiBlackSheep's Avatar
Drives: 2012 2SS/RS, 1968 SS
If your trans has hard part failure AFTER a flush is done... then you already had transmission issues and it was just a bandaid at that point.
I would still get it done, if you feel like your trans should still be strong (as if it's been mostly highway miles, why not?) then get it flushed. If you are afraid of any issues arising, then I do agree just doing a pan drop, filter swap, and replacing half the fluid is better than doing nothing.
LS3 Crate Engine Swap | CSP Custom Cam 232/240 .615/.615 113 +3 | Stainless Power LT Headers | Z28 Intake | Borla S-Type Exhaust | FTI Triple-Disc Billet 3200 Stall
2012 Camaro 2SS/RS | 1968 Camaro SS | 2020 Cadillac CT5 Premium Luxury | 2021 Spark LS
ChibiBlackSheep is offline   Reply With Quote
Old 03-19-2018, 07:57 PM   #6
geminisbro
geminisbro's Avatar
Thanks to Polizzio and y'all for the great responses. Much better than the mechanic(s) was, lol.
Old 03-20-2018, 06:01 PM   #7
polizzio
polizzio's Avatar
You're welcome. Let us know what you do, and how it all works out in the end.
Old 03-20-2018, 07:05 PM   #8
Deputy347k9
Deputy347k9's Avatar
Drives: 2014 Ashen Gray Convertible
I was just reviewing my note regarding servicing the Camaro. I have written differential 75W-90 (1 quart( at 45K, 90K, 135K. Transmission (Dexron-VI 6.7 quarts) at 97,500 miles. For the engine I only use Royal Purple HSP 5-30.
Deputy347k9 is offline   Reply With Quote
Old 03-20-2018, 07:18 PM   #9
KenKat
KenKat's Avatar
Drives: 2014 2LT RS Summit White
For my 2014, auto trans fluid change is indicated at 45k but next to that it indicates “(Applies to: Severe)”. So, you may be fine to change at 100k.
https://my.chevrolet.com/content/dam...t%20Camaro.pdf
KenKat is offline   Reply With Quote
Old 03-20-2018, 08:13 PM   #10
StreetRage320
Those who need me got me
StreetRage320's Avatar
Drives: 2022 ZL1 A10
Transmissions with heavy wear will have abrassives mixed/suspended in the fluid, ironically the abrasives can assist and help prevent slipping where tolerances are not longer to spec. The theory is that if you flush them out with clean transmission fluid, the result can be you loose the abrasives in the fluid and now you may have slipping issues.
IMO I would proceed with your fluid/filter/gasket change.
good luck op
StreetRage320 is offline   Reply With Quote
Old 08-31-2018, 12:03 AM   #11
jcampos
jcampos's Avatar
Drives: 2014 Chevy Camaro SS
That sucks. Changed mine plus rear differential at the same time when I hit 25k. Then changed both trans and diff again at 50k. I will probably be leaving mine alone for a good while now. Of course, I have an LS3
jcampos is offline   Reply With Quote
Old 08-31-2018, 06:46 AM   #12
mr_honez
Wifey Lover
mr_honez's Avatar
Drives: 2013 2LT to 2SS Manual Conversion
Got mine done @ 100K. Has 10K more on it now, and shifts great.
mr_honez is offline   Reply With Quote
Old 08-31-2018, 10:43 AM   #13
DSX_Camaro
DSX_Camaro's Avatar
Drives: 2013 SW 2LT/RS LFX/AY6
Yeah, with a V6 auto I'd also have the differential fluid changed now. You don't have an LSD so you don't need to change it as frequently as manual V6 / SS guys. But auto fluid change is a good idea. Would recommend doing it at 50k after this though.
DSX_Camaro is offline   Reply With Quote
Old 08-31-2018, 10:48 AM   #14
mr_honez
Wifey Lover
mr_honez's Avatar
That is the plan now.
flush, transmission fluid
