Old 03-18-2018, 08:00 PM   #1
Blueovalman
Blueovalman's Avatar
Drives: 2012 V6 Camaro 2010 Camaro SS
Question Need help with code P2099 bank 2 System Too Rich?
2012 Camaro V6 76000 miles no modifications besides a drop in K&N air filter one month ago code P2099 with check engine light came on. Replaced bank 2 down stream 02 sensor and code was clean and did not come back. Now one month later code P2099 bank 2 system too rich with check engine light is back. Recommended fix is to replace fuel injectors and/or intake manifold gasket? How can I fix this code and what do I need to replace? Is this 2012 Chevrolet Camaro V6 a lemon?
Mr. Clean
Blueovalman is offline   Reply With Quote
Old 03-18-2018, 08:51 PM   #2
Blueovalman
TTT
Mr. Clean
Old 03-21-2018, 05:50 AM   #3
Blueovalman
Are the Chevrolet Camaro V6’s meant to run only on 87 octane gasoline??
Mr. Clean
Old 03-21-2018, 11:38 AM   #4
Dizzy82
Dizzy82's Avatar
Drives: 2011 1LT/RS A6 RJT SuperCharged
You can run higher octane. Prior to my FI I used plus fuel. Have you tried running some fuel injector cleaner in the gas?
BMR sub frame brace, BMR tunnel brace, LSR sways, LSR CM ca & tl, Sphon ExD el, GM tower brace, Megan EZ Streets, Goodridge Stainless Steel Braided brake lines, PowerStop D/S rotors & pads, Doug Thorty Ceramic Shorties, Magnaflow x-pipe, MRT V2.0, KICKER PowerStage sub & amp, Infinity speakers & tweeters, Viteese Throttle Controller, Viteese Paddle Shifters, ACS T2 Splitter, ACS T2 Ports/Quad LED lights, VDI kit, Havoc diffuser, IPF ECU/TRANS tuned, IPF/KPE Supercharged. 364RWHP/297RWTQ
Dizzy82 is offline   Reply With Quote
Old 03-21-2018, 08:53 PM   #5
cawengr
Drives: Classy
Read up on the P2099 code here https://www.obd-codes.com/p2099 looks like you need to do some troubleshooting or take it to a mechanic and have them troubleshoot.
cawengr is offline   Reply With Quote
Old 03-23-2018, 01:32 AM   #6
Blueovalman
Have been using Chevron Plus 89 octane in the Camaro. I have tried Chevron fuel injector cleaner before it works well I think I may try a bottle. There is a mechanic here in Tampa that will be diagnosing it soon. I am surprised you guys don’t know??
Mr. Clean
Old 03-25-2018, 10:08 AM   #7
Pro-tuned
Angewendet Ingenieur
Pro-tuned's Avatar
Drives: 14 Camaro ZL1
You need to have sensors checked upstream and downstream. Make sure reading are consistent. The dealer or tuner can check these readings. If the reading are relatively the same look for leaks intake or exhaust between engine and cats.
LQ9, Iron Block, Forged internals, 408CI, Jannetty custom cam, TS short block, Whipple, Hardened Jackshaft, PRC 260, 2X3 Dynatech Full Competition, HF Cats, CAI, NW 103, Chee, ID 1300, COPO Breather, MSD, Fore Dual Pump, ultratorque, E85, dual Meth, True Trac, 3:45, 1500hp axle-shafts, DSS CF, BMR, custom Pearl/Candy paint by Jaidah.
Pro-tuned is offline   Reply With Quote
Old 03-27-2018, 03:03 AM   #8
Blueovalman
Finally got this Camaro fixed replaced the bank 2 up stream 02 sensor and left side catalytic converter was completely clogged and had to replace the left side catalytic converter.
Mr. Clean
