03-21-2018, 08:36 AM | #1 |
Best none slippage serpentine belt
I want to upgrade my serpentine belt. I have the older tvs 2300 magnusion with a 3.6 pully and stage 3 cam. What is the best belt. Ive heard of a green belt by gates. Any others to consider. Best for no slippage. Anyone have a length or part number for my setup? Thanks
2012 zl1 stock 7000 miles
2010 TVS2300, BTR cam PD stage 3, ID1050 injectors, CHE bronze trunnions, 7.400" pushrods,.660" lift platinum springs, Titanium ret, Zl1 fuel pump, Kooks LT headers, High flow cats, Roto Fab CAI, Corsa exh., Mellings oil pump, HD chain, ls2 damper, all synthetic, BMR control arms, zl1 toe link, BMR cradle mounts, W/bottle relocation, air scoop deflector, Hennessy wheels, two piece rotor, morimoto fogs, DRL harness, coilovers, Heads up install, mgw shifter, slps splitter, slp spoiler, zl1 side skirts, painted strips, debadged, tinted, 2018 emblems. Edit Signature |
03-21-2018, 09:59 AM | #2 |
'It's an experiment'
Do you have a gates belt on it now? If so, using that number, add rpm to it and you can use that to search...
Gates RPM belts are designed for racing and are very good. -Don
747 RWHP 794 RWTQ
03-21-2018, 01:05 PM | #3 |
No i dont i have the one from the supercharger kit.
03-21-2018, 01:41 PM | #4 |
Drives: 2011 Camaro 2SS Join Date: May 2016
Go with a gates RPM belt like stated above, they last long and the really take one hell of a beating
2010 Camaro 2SS-Mods: Nightfury cam, CNC ported LS3 heads, CNC ported TB, Ported Intake, RX Catch Can, MGW Short Throw Shifter, Mantic 9000 Clutch, TSP 1 7/8 headers, catless NPP, BMR trailing arms, MMR Z/28 Reps 20" gloss black. SOLD
2011 Red Jewel Tintcoat 2SS-Mods: Edlebrock E Force S/C w/ 3" pulley swap,Texas Speed roller Boost Cam 227/235, 641"/649", 114 LSA, PRC Ported Heads, Ported TB,ARH 1 7/8 headers, McLeod RST twin disk 1000 hp clutch, ZL1 Fuel Pump, 620whp |
03-21-2018, 03:01 PM | #5 |
how did you find the right length belt.
03-21-2018, 05:16 PM | #6 |
Angewendet Ingenieur
Drives: 14 Camaro ZL1 Join Date: Apr 2015
The “green” belt is a commercial grade belt and works well as RPM. Often part numbers on belts are relative to length and no of ribs. If you can’t read the part number you can use a string and measure the distance. Finally and most often overlooked is proper belt adjustment ( it’s not what you think but what the mfg. suggests. For example Whipple has 2 different adjustments one for a 2010 and one for 2014. “follow mfg. recommendations”
LQ9, Iron Block, Forged internals, 408CI, Jannetty custom cam, TS short block, Whipple, Hardened Jackshaft, PRC 260, 2X3 Dynatech Full Competition, HF Cats, CAI, NW 103, Chee, ID 1300, COPO Breather, MSD, Fore Dual Pump, ultratorque, E85, dual Meth, True Trac, 3:45, 1500hp axle-shafts, DSS CF, BMR, custom Pearl/Candy paint by Jaidah. |
03-21-2018, 05:55 PM | #7 |
Gates are like this:
K080675 08 is rib count 0675 is 67.5 inches (68" OC) Then: HD is heavy duty RPM is racing belt So, if I know the length, you can find the gates belt I have: K080675RPM for my LSA... The HD belts are a bit stiffer rubber vs the RPM as the RPMs are a racing designed belt vs HD which are industrial in design... HD and RPM run just a bit tighter... -Don
747 RWHP 794 RWTQ
03-21-2018, 07:00 PM | #8 |
Drives: 2010 Camaro SS Join Date: Jan 2015
There are some good videos on YouTube showing how to measure for a belt.
03-21-2018, 08:36 PM | #9 | |
03-21-2018, 08:38 PM | #10 |
thanks, I'll check that out. looks like that the way to go now Ill have to take it off and measure it.
03-21-2018, 08:41 PM | #11 | |
03-22-2018, 02:41 PM | #12 |
Drives: 2014 Camaro SS Black Widow Join Date: Mar 2018
03-22-2018, 02:50 PM | #13 |
Ive shredded 2 8 rib green belts with a stock gm tensioner pulley. Just ordered this new pulley and looking for a stronger belt. Got 850hp
03-22-2018, 04:41 PM | #14 | |
