Old 03-22-2018, 03:50 PM   #1
metrogdor22
Drives: 2013 2SS M6
Cammed 2-step = dangerous?
I have a 2013 2SS M6 that I'm getting a cam and off-road headers installed on. I know a 2-step will cause problems with cats, but with those gone, is there other danger?
My main concern is since the cam has more overlap, does that open the possibility of the after-fire traveling back into the intake? Does the extra pressure on the back of the exhaust valves from ignition in the exhaust cause any problems?
I guess my real question is, what danger does a 2-step pose to an N/A, cammed, catless car? I don't intend to use it much; just enough to ensure I don't get asked to babysit my 1 year old nephew.
metrogdor22 is offline   Reply With Quote
Old 03-22-2018, 03:53 PM   #2
LsxDoctor
15 Year LS1Tech Member
LsxDoctor's Avatar
Drives: 2010 ss 391ci LS3
Not sure if serious
LsxDoctor is offline   Reply With Quote
Old 03-22-2018, 03:55 PM   #3
metrogdor22
Drives: 2013 2SS M6
Originally Posted by LsxDoctor View Post
Not sure if serious
I am.
Old 03-22-2018, 03:59 PM   #4
LsxDoctor
LsxDoctor's Avatar
"After fire" will not travel back into the intake. You'll be fine. Many people have ran a two step in cam only Lsx cars for years. Try doing a search.
Old 03-22-2018, 04:03 PM   #5
metrogdor22
Drives: 2013 2SS M6
I searched "2 step danger" and got to page 3 without finding anything related to 2-steps.
FYI: https://www.quora.com/What-is-the-di...kfire-in-a-car
Old 03-22-2018, 04:13 PM   #6
SynergyGreenSS
SynergyGreenSS's Avatar
Drives: 2011 2SS
My car is cammed with 2 step. No issues so far!
2011 SS L99
LSA Supercharger, BTR Stage 3 PDS Cam, Yank 3200SS, Weapon X Stage 2 intake, LSA Heads, Flex Fuel, Ported throttle body, Speed Engineering Headers, NOWEEDS, ZL1 fuel pump, DSX AUX Pump, ID-1050X injectors, 3” pipe to NPP mufflers, 3.91 gears
SynergyGreenSS is offline   Reply With Quote
Old 03-22-2018, 04:17 PM   #7
metrogdor22
Drives: 2013 2SS M6
Thanks! How about the cam? How many miles do you have with the cam and with the 2-step? Anything you dislike about either?
Old 03-23-2018, 01:04 AM   #8
SynergyGreenSS
Drives: 2011 2SS
I only just put the 2 step on about 2 weeks ago, or about 200 miles ago, so not a ton of experience with it yet although I have absolutely no issues or complaints. I don’t think I know of anyone who has had any issues because of it
2011 SS L99
Old 03-23-2018, 08:11 AM   #9
pyroguy
Started#gottalovethatblue
pyroguy's Avatar
Drives: ABM #832
This may be an ignorant question, but what is a 2 step?
Check out my build thread
Old 03-23-2018, 08:42 AM   #10
SynergyGreenSS
Drives: 2011 2SS
It’s a type of launch control that can be activated with a clutch or brake pedal or really however else you want. The limited can be set wherever you want, allowing for consistent launches every time
2011 SS L99
Old 03-23-2018, 10:12 AM   #11
Badbubba
GrINned & JUICEd
Badbubba's Avatar
Drives: 15STI, 10Expy, 10 2SS/RS M6, 47KB1
What components did you use for your 2 step? CTAP? And?
GPI SS3 Cam & stuff,N.O. Plate(dedicated fuel tank,progressive,fuel hose upgrade,remote opener,heater,console switches),LNC2000,CTAP,ARH 1 7/8" LTs/gutted cats/X pipe/mufflers,Jet Hot coated LTs,GPI HPT Tune,CAI, Scoop,Rx Catch Can,Gates heater hose relocation, Remote clutch & auto brake res,Metco loop,Momentum Tunnel Brace,TSW Nurb 18",555 & 05,Pfadt trailing arms & toe rods,Autometer WB,Fesler Pillar Pod,LED strips (int),Lloyds floor & trunk mats,LED DRL/front turn & license plate,DRL harness,VLEDs tail lights,Plasticoat Bowties. Ord: Oct 5, 2009 Rec: Nov 19, 2009 13.17@112.6 stock
Badbubba is offline   Reply With Quote
Old 03-23-2018, 10:17 AM   #12
Badbubba
GrINned & JUICEd
Badbubba's Avatar
What is the risk of wetting down the cylinder walls with unburnt fuel by using an ignition cut 2 step?
Old 03-23-2018, 10:24 AM   #13
SynergyGreenSS
Drives: 2011 2SS
For now, mine is just set up to a toggle switch. It’s good for roll racing because I can set the limiter to like 4K where I’m making good power, flip the switch on, get up to the limiter, then flip it off and go. At some point I’ll wire it to my brake (I’m an auto, but I have a somewhat high stall) and I’ll set it to like 2k for dig racing but I won’t be doing any of that for a while.
2011 SS L99
Old 03-23-2018, 10:28 AM   #14
SynergyGreenSS
Drives: 2011 2SS
I’m no professional, but shouldn’t dumping fuel into the cylinders without igniting it have something of a cooling effect? Or am I way off?
2011 SS L99
2 step, cam, cats, headers
