Old 03-23-2018, 08:56 AM   #1
eLeSthree
Drives: 2011 Camaro SS 6sp
Boost Math reading wrong
Posted this on HPTuners, but its kinda slow over there.
I know I'm running about 10psi, but my scanner only shows 2. i'm using the built in Boost Math parameter to read boost.
This is on the stock MAP sensor.
What am I doing wrong?
2011 Camaro SS---SOLD
TMS Dart 427 FED M311s, ESS Tuning G4 Blower, DSX Triple FP Assembly, DSX FF, FIC1300, Mcleod RXT 1200HD, Edlebrock Pro Flo XT
1158whp 1017wtq.
2010 CTS-V A6 - "Stock" SOLD
630whp 658wtq
2024 F-150 RCSB 5.0 4x4
waiting for tunes...
eLeSthree is offline   Reply With Quote
Old 03-24-2018, 05:20 AM   #2
miller8907
miller8907's Avatar
Drives: 2014 1SS/RS LS3
You need a 3 bar map sensor from a ZL1. Stock SS is only 1 bar.
2014 1SS/RS LS3 AGP TT, Custom TSP Cam, 4L80E Swap 1/4 mile- 9.53 @ 145mph
miller8907 is offline   Reply With Quote
Old 03-24-2018, 10:29 AM   #3
JANNETTYRACING
JANNETTYRACING's Avatar
And change setting in your tune to go with the MAP sensor.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 03-26-2018, 10:59 AM   #4
eLeSthree
Thanks guys. Its misleading that the stock map is 1bar, you’d think it could read up to 14psi, but apparently 2.2psi is the max. Turns out Howard tuned my car on maf only so it doesnt really matter.
Ted, im gonna shoot you a pm later regarding your fpcm. Fuel pressure is dropping at redline to 48psi. My injector DC is only 55% and it doesnt go lean, but its concerning. Wonder if the zl1 fpcm is the answer for me...
1158whp 1017wtq.
630whp 658wtq
Old 03-26-2018, 11:17 AM   #5
JANNETTYRACING
14.7 psi is our atmospheric pressure at sea level.
The 1 bar map sensor just so happens can read up to 16.9 psi or 2.2 boost.
The MAF tuning will remain exactly the same.
Go to Howard, buy and install the map sensor and have him update your tune, you will then be able to read boost through your OBDII port.
Our FPCM will correct that pressure for you, the tune will also need to be updated for that as well, I will provide Howard with the data.
Ted.
Old 03-26-2018, 01:47 PM   #6
eLeSthree
Ted.
I think I'll be able to handle the tune portion of changing the map sensor scale. Thanks to the fellas on hptuners forum I got the part number for the LS9 MAP sensor, and I'll just grab a ZR1 tune file and take what I need from there.
thanks for the help Ted.
Undecided on fpcm. I want to run E85 but dont think zl1 stuff will cut it.
1158whp 1017wtq.
630whp 658wtq
Old 03-26-2018, 02:05 PM   #7
JANNETTYRACING
Good deal on the MAP.
No sir it won't handle E-85, I would recommend a Fore innovations return system and ID-1050X injectors.
Ted.
Old 03-28-2018, 08:34 PM   #8
eLeSthree
Got the 3bar map, changed the tune, all is good!
Thanks
1158whp 1017wtq.
630whp 658wtq
Old 03-30-2018, 07:55 PM   #9
JANNETTYRACING
Thanks
