Old 03-23-2018, 07:50 PM   #1
mr_double_s
Drives: 5th gen z28
Just some question bout the z28(new owner)
Hello,
1.I just bought the z28 this week. It was basically an upgrade from the SS. I noticed some different things when I was testing the car out. When I accelerated the car and shifted gears the RPM's would shoot up when I released the clutch after shifting the gears. Is that normal or do I need to be concerned about the car?
2.Also do they offer the z28 rim at chevy or do I have to settle for replicas. I'd like another set of the rims.
mr_double_s is offline   Reply With Quote
Old 03-23-2018, 07:53 PM   #2
joelster
joelster's Avatar
Drives: '94 Z28+ '15 Z/28
1. Sounds like the clutch may be slipping a bit.
2. I'm sure there is a part number somewhere since the car is only a few years old, but you'll pay 5x as much on a GM wheel as you will on a replica.
1973 Mach 1, 351C cruiser
'15 Z/28 Red Hot, A/C
1980 Z28- resto-mod project
1979 Y84 Trans Am
1986 IROC-Z
joelster is offline   Reply With Quote
Old 03-23-2018, 08:01 PM   #3
joelster
joelster's Avatar
Part numbers for front are 22873225
Part numbers for rear are 22873227
https://www.gmoutletparts.com/oem-pa...wheel-22873227
https://www.gmoutletparts.com/oem-pa...wheel-22873225
1979 Y84 Trans Am
1986 IROC-Z
Old 03-23-2018, 08:09 PM   #4
mr_double_s
Drives: 5th gen z28
appreciate the reply first of all.
Just wanted to check out the prices on the rims. Was considering getting another set.
As for the slipping, I guess I will be heading to chevy to get checked out. I was hoping it wouldn't come to that.
Old 03-23-2018, 08:26 PM   #5
Test_Eng
Drives: 2013 1SS RS 1LE NPP ADM LSA CON
Does it have a Auto Blip on it?
https://youtu.be/1_G7mutI-Ik
Test_Eng is offline   Reply With Quote
Old 03-24-2018, 12:28 AM   #6
td195f
td195f's Avatar
Drives: 2015 Z/28 #786
It's been awhile since I bought my spare set of wheels but I paid about $600 per wheel plus there's a $50 core charge per wheel. so $650 per wheel.
2015 Z/28 #786 - Black
2004 Silverado 3500 Dually - D'Max - Suncoast - Banks - Edge - Custom Tune by D'Max Tuner / Spitzer '32 Bantam Altered Drag Car - Blown Alcohol 380 CI Small Block Chevy
td195f is offline   Reply With Quote
Old 03-24-2018, 06:35 AM   #7
Zslash28
Jumanji
Zslash28's Avatar
Drives: '14 Z/28 - AGM - No A/C
Clutch for sure, had a drag bike that did this with a bad clutch.
Keep an eye on the Ebay, Facebook forums, and here for used sets of OEM WHEELS, they pop up often.
Keeper of the 5th Gen Z/28 Registry.
Registry Facebook.
Follow: @5th_gen_z28_registry
I track wrecked Z/28s Total lost -41
Zslash28 is offline   Reply With Quote
Old 03-24-2018, 01:32 PM   #8
pat_t
Drives: .
I had some issues with the clutch on my Z28 which only had 1000 miles on it at the time.
I replaced the friction plate and pressure plate and all was well afterwards.
I think my issue was due to adjustment of the preload on the pressure plate being done incorrectly as after visual inspection there didn't seem to be anything obvious wrong with the parts we removed. I kept them as spares for now..
pat_t is offline   Reply With Quote
Old 03-26-2018, 09:32 AM   #9
frenchsquared
frenchsquared's Avatar
Drives: 15 Z28, 01 Corvette, 96 Corvette
The replicas are not the same wheels. Get the factory ones. You can get them from GM I have had to replace one. As others have said they show up on ebay from time to time.
There is a reason the replicas are so cheap. They are not even close to the same quality wheel.
2018 Sierra RCSB | 2015 Z28 Camaro | 1989 B2200 with a 327 | 1996 LT4 Z51 Corvette | 1973 427 Nova
frenchsquared is offline   Reply With Quote
Old 03-26-2018, 04:44 PM   #10
ronchev
ronchev's Avatar
Drives: 14' Red Z/28 #336
Also the replicas that I have seen do not the same back spacing or width as the GM Z/28 wheels do, also just a cast wheel made to look like the real ones but more for they guys that want to put Z/28 look wheels on there none Z/28 camaro
ronchev is offline   Reply With Quote
Old 03-26-2018, 10:20 PM   #11
mr_double_s
Drives: 5th gen z28
I'll get her up to chevy asap for the clutch problem. I knew something was wrong. She didn't feel right at all. As for the replicas I had no intention of purchasing them. I was just making sure that I was right an not cheating myself by getting the gm wheels and paying all that money. I'll let you guys know whats going on with the car as soon as I do.
