Old 03-24-2018, 02:05 PM   #1
Meryl70
Drives: 2010 Camaro SS - Rally Yellow
L99 Supercharger Suggestions
Hi. I have a 2010 Camaro automatic and I really want to add a supercharger along with the CAI. I was looking at Edelbrock but I’m not 100% sure as I’ve been reading that the Magnuson is better.
Can someone let me know what would be a good package to purchase? Looking to spend up to 8k on the kit.
Thanks.
Meryl70 is offline   Reply With Quote
Old 03-24-2018, 02:41 PM   #2
ecreps
Drives: 2014 1LE, 1996 z28
If it were my money I would get the ECS 1500 kit.
ecreps is offline   Reply With Quote
Old 03-24-2018, 03:37 PM   #3
Moreair1
Moreair1's Avatar
Drives: 2011 ss convertible
What kind of driving will the car see and also what are your goals power wise
Cai intake and a few other mods😎
Moreair1 is offline   Reply With Quote
Old 03-24-2018, 04:36 PM   #4
Meryl70
Its garaged in the winter so I only drive it from April - October. Its not my everyday car so it has very low mileage. I’m looking to get close to 600hp but will settle for 550hp.
Old 03-24-2018, 05:39 PM   #5
scv_guy
scv_guy's Avatar
I'd first suggest the AGP twin turbo kit, easy install and will make your goal with ease. If your stuck on a supercharger Maggie TVS2300...
scv_guy is offline   Reply With Quote
Old 03-24-2018, 06:19 PM   #6
AGP Turbo
Drives: All things Turbocharged
+1 AGP TT
Takes 80-90hp more to run a supercharger at that power level than a good efficient turbo system. So what would get you 550whp on a blower puts you around 640whp on a turbo for free, with the same stress on the engine.
Without swapping a cam or anything else, our base TT system will put you right in the 600-650whp range with nothing else needed but what comes in the box.
AGP Turbo is offline   Reply With Quote
Old 03-24-2018, 09:36 PM   #7
pyroguy
Keeper of “THE list”
pyroguy's Avatar
Drives: ABM #832
If you’re looking for 550-600 rwhp then go with ADM performance stage 3 kit. It should save you a boat load of money and get you right at your goals. It includes a smaller upper pulley, a cam, bigger injectors, etc.
If you have to have one of your original two options I’d go with a Maggie Heartbeat supercharger. It has a superior design over the Edelbrock.
Check out my build thread
Old 03-24-2018, 09:44 PM   #8
Rob10CamaroSS
Drives: 2012 ZL1 Redline Phase 4
I have the identical set up
Get the best of both worlds, or what I like to call a belt driven turbo.
You can hit those power levels NO PROBLEM with a Procharger Centrifugal Supercharger and there are many advantages imo.
I've had 11 Supercharged Vehicles over the years; Roots, Twin Screw, & (3) Centrifugal set ups. Dont get me wrong there's nothing like big boost going through a twin screw or roots supercharger (IF THE MOTOR CAN HANDLE IT). BUT with low to moderate boost on a non built motor I prefer the Centrifugal for a few reasons. For starters it only gives you that extra power when you want it, which means it only puts that extra stress on the motor at those times. And the way it delivers the power is very much like a turbo meaning it just keeps pulling and pulling and pulling. Best part is because of the design you can get amazing gas mileage (if it matters) have oem comfort and manners, but touch the go pedal and HOLY WTF JUST HAPPENED.
I have a High Output Stage II Set Up with an Upgraded 3 Core Intercooler, Pro Flow Surge System, Drilled & Pinned Crank Balancer, (3) Procharger Pulleys, etc... Skys the limit on the amount of HP it can make, it all comes down to how much are you willing to push the motor, LOL ....
Not the most beautiful set up but I drive with the hood down and don't fear anything that pulls up next to me
2012 ZL1 w/Redline PHASE 4-ZL Performance Package
Rob10CamaroSS is offline   Reply With Quote
Old 03-24-2018, 09:51 PM   #9
RedTexasSS
Drives: 2012 SS Red w/ black rally stripes
I'm very pleased with the Magnuson Heartbeat. Have not put it on the dyno yet.
2012 SS Camaro, Victory Red w/black rally stripes, SLP front splitter, ZL1 Rocker panels, ZL1 Add-ons Stealth Wickerbill, L99, Magnuson Heartbeat supercharger, 65 lb. injectors, 87 mm pulley, ZL1 fuel pump, ADM FPCM,1 7/8 Texas Speed long tube headers, v-max ported throttle body, Rotofab cold air intake with Apex scoop, Apex catch can, MSD plug wires, AEM AFR and Boost gauges, GPI SS1 VVT Cam, HP tuners with remote tune by Ryan at GPI, Solo axleback exhaust w/j pipes and stock resonator.
RedTexasSS is offline   Reply With Quote
Old 03-24-2018, 10:37 PM   #10
Moreair1
Moreair1's Avatar
For that power level I would do a lsa blower, it saves you money for other parts, like a zl1 fuel pump, suspension ect., but on that note I do love my agp tt kit.
Old 03-25-2018, 12:38 AM   #11
Pro-tuned
Angewendet Ingenieur
Pro-tuned's Avatar
Drives: 14 Camaro ZL1
It’s a major investment, consider exactly what you expect, how will it be used, and your budget. Make a plan. What works for someone else might not be ideal for your application. Good luck.
LQ9, Iron Block, Forged internals, 408CI, Jannetty custom cam, TS short block, Whipple, Hardened Jackshaft, PRC 260, 2X3 Dynatech Full Competition, HF Cats, CAI, NW 103, Chee, ID 1300, COPO Breather, MSD, Fore Dual Pump, ultratorque, E85, dual Meth, True Trac, 3:45, 1500hp axle-shafts, DSS CF, BMR, custom Pearl/Candy paint by Jaidah.
Pro-tuned is offline   Reply With Quote
Old 03-25-2018, 11:14 AM   #12
UBB
UBB's Avatar
Drives: 2018 ZL1
I'm in the same situation. Though my (expected gains)won't be as high as yours I went with the Heartbeat based on the instant trq a SC provides and the reliability it's reported to have. It is not cheap and for me was a hard check to write for a car that sits in the garage 6 months of the year but you only live once.
UBB is offline   Reply With Quote
Old 03-26-2018, 06:43 AM   #13
Missile Man
Missile Man's Avatar
Drives: 2010 2SS/Black
I installed the Maggie on my 2010 L99. Didn't have to pull the fascia. I have the Cold Air inductions intake. I had to buy a new connecting pipe from the SC to the CAI but they make them.
Note: If you have a early 2010, you should have the dealer update your ECM firmware before you install the SC. I ordered mine in 09 and the ECM firmware was missing the SC tables so no matter what I did, the Camaro wouldn't start after the SC install. I had to take it to the dealer to load the stock firmware then my tune worked.
2010 Black 2SS L99
Mods:
* CAI Intake
* Magnuson MP2300 TVS Supercharger/RDS Spacer
* Vector Motorsports Tune
* Stainless Power LT/Hi Flow Cats/Tru X-* Pipe/36" J-Pipes/40 Series
* R1 Concepts ceramic pads and slotted/drilled rotors
Missile Man is offline   Reply With Quote
Old 03-26-2018, 09:11 AM   #14
hammdo
'It's an experiment'
hammdo's Avatar
I did the ADM LSA conversion with GPI heads/cam package. Like what that did. ADM LSA conversion best bang for the buck...
-Don
747 RWHP 794 RWTQ
