Old 03-24-2018, 06:35 PM   #1
scooterss
Drives: 2010 Camaro SS
Loud Corsa
Long tube headers ,cat delete and 3 in Corsa cat back pretty loud. Anyone ever install a magnaflow resonated x pipe into something like this? Just want to tone it down a bit and a deeper tone.
scooterss is offline   Reply With Quote
Old 03-24-2018, 07:00 PM   #2
rontammy0
Drives: 2011 2SS/ RS INFERNO ORANGE L99
Do you have a vid?
rontammy0 is offline   Reply With Quote
Old 03-24-2018, 08:15 PM   #3
scooterss
https://m.youtube.com/watch?v=NyIJX8yrwJU
Old 03-24-2018, 09:18 PM   #4
13SSCamaro
13SSCamaro's Avatar
Drives: 2013 Camaro SS
I had the same setup and it was way too loud, i ended up installing TSP high flow cats and it is perfect now
2013 SS M6, TSP Stage 3 231/246 cam kit, TSP Trunion upgrade, Cold Air Inductions CAI, VMAX PTB, TSP 1 7/8 Long tube headers and high flow cats, Corsa Xtreme ZL1 Catback exhaust, Elite E2-X Catch can, Trick Flow Gen-X 255 heads milled 0.025 and valve job, GPI rod mod and ported intake, ID850 injectors,ZL1 fuel pump, Flex sensor and E-85, Mantic 9000 and 1LE 3.91 diff 512rwhp/462rwtq
13SSCamaro is offline   Reply With Quote
Old 03-24-2018, 09:36 PM   #5
scooterss
I would like that but since My car is a FI car. I cant run cats. Don’t want to take the chance of melting the cat.
Old 03-24-2018, 10:49 PM   #6
mlee
CamaroFans.com
mlee's Avatar
Drives: ZLE & ZR2
A couple guys on here installed solo resonators in their Corsa system for the same reasons you have and it worked well. I'll try and find the posts
Edit: Here you go...
http://www.camaro5.com/forums/showpo...&postcount=209
http://www.camaro5.com/forums/showpo...&postcount=216
http://www.camaro5.com/forums/showpo...&postcount=218
Old 03-24-2018, 11:03 PM   #7
scooterss
Thanks I will check into those.
Old 03-25-2018, 10:41 AM   #8
patternpilot
patternpilot's Avatar
Drives: 2012 2SS/RS
I am in the same situation. Corsa, cat delete and F.I.
I tried the Magnaflow muffled x-pipe but it was no help. I ended up removing the ex-pipe and installing the resonators that came on the stock exhaust which helped but still not to the level I want. I prefer a more stealthy sound so I am taking the Corsa mufflers off and installing the Flowmaster Force 2 axle-back. If that is not enough I will take a look at other resonators. Flowmaster tells me this is the quietest performance system they make so we will see. I also have some 200 cell steel cats I am installing which may help as well. My goal is to be able to go out and have fun with the car without drawing unneeded attention.
There's more to life than gas mileage
LS3, Whipple, Custom Comp Cam, springs, pushrods, timing set, CAI intake, Apex cold air scoop, Doug Thorley TRI-Y headers, Billet Custom Products baffled Valve covers, Mighty Mouse Catch can, ADM FPCM, ZL1 fuel pump, MSD boost-a-pump, Hex Vent hood vents, ProSport gauges(fuel pressure, AFR, Boost), Corsa, 100 cell Cats. Jannetty remote tuned, Pfadt trailing arms, all parts user installed. No Dyno yet. Manual trans. 3.45 gears.
patternpilot is offline   Reply With Quote
Old 03-27-2018, 03:39 AM   #9
Blueovalman
Blueovalman's Avatar
Drives: 2012 V6 Camaro 2010 Camaro SS
I would have to agree this exhaust set up is too loud for a lot of people and most people end up installing high flow catalytic converters.
Mr. Clean
Blueovalman is offline   Reply With Quote
