Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Marketplace > Members Classifieds - Parts for sale or wanted > V6 - Engine, Exhaust, Bolt-Ons, Tuning Equipment
Old 03-25-2018, 07:58 PM   #1
PyroLT
PyroLT's Avatar
Drives: 2015 AGM 1LT
FS: Elite Catch Can, CAI intake, washer relocate and air scoop
I have the following parts for sale off my 2015 LFX.
Dual port Elite Engineering Catch Can and Clean Side Separator: $75
This has the upgraded stainless lines and AN fittings. I also have fitting to go from AN to a 3/8 hose barb to make the connections on the valve cover and manifold. All included.
Cold Air Inductions intake: $75
This comes with the housing, MAF housing, silicone elbow, and filter. The air box is somewhat out of square, but the cover still fits and it fits in the car fine. There are two holes drilled in the back where the WW filler neck was.
Windshield washer relocate and Apex air scoop: $50
This has the pump, tank, and filler extension. ALL in fully working condition when I took them off.
Performance: Overkill Supercharger, VMAX ported throttle body, JacFab Intake and Spacer, VTC Throttle Controller, ARH Catless Downpipes, Magnaflow Res-X, Stock Resonator Delete, MRT V1 Axle Back, Solo J-Pipes, E85 flex fuel, MRR 228 20x10 and 20x11 wrapped in MPSS,
Cosmetic: 15% Tint on side Windows 5% on back, LED fogs, SS bumper conversion, de-badged, Z28 front grill, Eagle Eye headlights, HID conversion, VIS terminator hood, Red LED sidemarkers with 5% tint.
PyroLT is offline   Reply With Quote
Old 03-25-2018, 08:32 PM   #2
Glock17
Glock17's Avatar
Drives: 2012 Imperial Blue RS
Will this oil Sep fit 2012?
Glock17 is offline   Reply With Quote
Old 03-25-2018, 10:28 PM   #3
PyroLT
PyroLT's Avatar
Do you mean the full catch can and clean side package?
Old 03-25-2018, 10:51 PM   #4
DSMer1
Drives: 14 and 15 SS's
Pmed on catch can setup
DSMer1 is offline   Reply With Quote
Old 03-26-2018, 12:07 AM   #5
Jayjellyfish212
Jayjellyfish212's Avatar
Drives: 2014 1LE
Why are you getting rid of your parts bro?
Car mods: never enough!
Jayjellyfish212 is offline   Reply With Quote
Old 03-26-2018, 12:18 AM   #6
PyroLT
PyroLT's Avatar
I got something better to take their place
Old 03-26-2018, 07:35 AM   #7
Deputy347k9
Deputy347k9's Avatar
Drives: 2014 Ashen Gray Convertible
The "Elite Catch Can" assembly looks like it's the Elite E2X system, that is one heck of a price. Couple of one way valves and your up and running at a huge savings.
I just installed this system on my 2014 and works like a fine tuned clock!
I am sure the first guy that sent a message will take the setup?
Deputy347k9 is offline   Reply With Quote
Old 03-26-2018, 08:29 AM   #8
Jayjellyfish212
Drives: 2014 1LE
Attachment 926165
Nice
you had me worried, because I know you have a lot into your car. I thought you were trading in or something. That is hell of impressive set up.
I'll take the catch can and clean air separator off your hands...I'm in need of the clean side sep to try to fit it for the 1LE, been wanting to mod one to fit the aftermarket valve covers I got on it.
Funny I just bought that same can and sep. for the wife's LFX build about a2 weeks ago brand new and was on here daily with no dice..
Old 03-26-2018, 12:29 PM   #9
PyroLT
PyroLT's Avatar
PMs responded to and catch can sale pending to DSMer1.
Deputy is also correct, with a small modification. The can is the E2 (The E2X is bigger and has a drain at the bottom, I have it now). Just checked, and brand new, the setup cost ~$360 dollars for the clean side, dual ports, and upgraded hoses.
Old 03-26-2018, 12:56 PM   #10
Tigerfan
Tigerfan's Avatar
Drives: 2013 Blue Ray Camaro
PM sent.
Tigerfan is offline   Reply With Quote
Old 03-26-2018, 02:17 PM   #11
who-dat
Drives: 2011 1ss
I'll take catch can if it falls through
who-dat is offline   Reply With Quote
Old 03-27-2018, 02:39 AM   #12
Jazzzed
Jazzzed's Avatar
Drives: 2015 Camaro LT
Where exactly does this washer relocation bottle mount inside the engine bay?
Jazzzed is offline   Reply With Quote
Old 03-27-2018, 04:18 AM   #13
Dylan1214
Dylan1214's Avatar
Drives: 2014 Camaro SS L99
Pm'd
MODS: GPI MAX Package ported and milled heads+(229/250,111 LSA),Johnson 2110 Lifters,BTR .660 Springs,CHE Trunnions,C5R chain,DSX Flex Fuel kit,LSA Injectors,ZL1 Fuel Pump,MAMO Ported MSD Intake manifold,BOWhite ported Throttle body,25% UDP,CAI Intake,Intake Scoop,Kooks 1 7/8 headers,Borla attak catback,Elite catch can,BMR Motor mounts,CircleD 5C 4000-4200 Torque converter,ADM trans cooler,Jannetty Trans dipstick,DSS Aluminum Driveshaft,3.91 Gears,Eaton TrueTrac,JRE Billet caps,BMR Trailing arms,BMR Toe rods,BMR rear sway bar,Pegasus Solid sub frame bushings,DSS 1,000HP Axles
Dylan1214 is offline   Reply With Quote
Old 03-29-2018, 01:56 AM   #14
Jc_SourPatch
Drives: 2014 2LT Camaro RS
What’s still available
Jc_SourPatch is offline   Reply With Quote
