Old 03-29-2018, 09:06 AM   #1
Ashen L99
Ashen L99's Avatar
Drives: Ashen grey, 1SS, L99
My luck lately #2
So, was messing around at a friends house, was wiping down the engine bay, had my friend turn the car over, and I see that the harmonic balancer is now vibrating pretty bad. Seeing how my luck with this car has honestly been bad, what's the worst case scenario?
Roto-fab big gulp, Nick Williams 102mm TB, Kong X-port LSA, Ported 821 heads, BTR stage 4 V2 pd cam, 416 CI bottom end, original block. TSP 2” long tubes, Corsa ZL-1 catback. Nitrous Outlet 102mm plate kit/100 shot JUST IN CASE. NGK BR7EF plugs with Taylor plug wires. DSX flex fuel kit, DSX aux pump, zl1 in tank. deatchwork 1000cc injectors. B&M deep trans pan, stock 6L90 converter, ZL1 diff 3.23 ratio. GM ground effects, T-Rex upper grill, Z/28 Spoiler, Forgestar F14s, 12” subwoofer, and custom paint matched interior.
Ashen L99 is offline   Reply With Quote
Old 03-29-2018, 10:14 AM   #2
Kopterman
Kopterman's Avatar
Drives: 2014 Bright Yellow 2SS/RS
Is it the stock balancer? I’ve read on here that they are known to break..
I changed mine to an ATI balancer.
Kopterman is offline   Reply With Quote
Old 03-29-2018, 10:30 AM   #3
h018871
Geoff
h018871's Avatar
Drives: 2022 SS 1LE
the pulley is loose on the crank and wore the snout down = new crankshaft
h018871 is offline   Reply With Quote
Old 03-31-2018, 03:35 AM   #4
Ashen L99
Ashen L99's Avatar
Yeah it's the stock balancer. We had a talk here recently. She got put in the garage. I went down to the store got a six pack, came back and I told her(Nina is the name of my car) as I was opening the first one, you keep acting up and heads, cam is Gonna half to wait. Thankfully I took it in and got told that it's not a abnormal amount of wobble or vibration. It was a good amount but not good enough I guess to warrant a replacement. So, I Put that on the to do list. New balancer when I tear it down.
Old 03-31-2018, 07:39 AM   #5
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
lol...had many of the same conversations over the years after sum liquid lubrication! problem I had was the lubrication was a slippery slope....enough of that!
I too am in the initial stages of getting the components together for a cam...and tryin to decide if a replacement balancer should be added.
anybody have experience with PowerBond balancers? look like a nice intermediate upgrade for a N/A motor.
peace!
Old 03-31-2018, 08:06 AM   #6
Buschman
Buschman's Avatar
Drives: 2018 ZL1 2015 1SS 1LE
Powerbond and ATI are always at the top of the harmonic balancer list, but for the LS3 my engine builder recommends the Fluidampr.
2018 ZL1
2015 1SS 1LE
Stock...ish
Buschman is offline   Reply With Quote
