Old 03-29-2018, 03:39 PM   #1
HAMBO
HAMBO's Avatar
Drives: Supercharged 2013 AGM 2SS/RS
Aftermarket CAI on an SLP TVS2300
Hi everyone,
Has anyone added an aftermarket CAI to their SLP TVS2300 using a kit like this one?
https://jannettyracing.com/products/...-camaro-ss-1le
I'm wondering whether it only works with the Cold Air Inductions CAI, or if it can be used to make other similar style CAIs work with the SLP supercharger (specifically, those that have the opening for the MAF within the connecting tube and not on the neck of the cone filter).
Thanks for any help!
HAMBO
2013 AGM 2SS/RS
SLP TVS2300, Edge CAI, 3" Magnaflow catback, BC Racing BR series coilovers, HRE FF15's (20x10 square) with Michelin Pilot Sport 4S's, GM STB, BMR front and rear sway bars and toe links, Prothane subframe bushings and front control arm inserts, JDP rear upper control arm bushings, Elite Engineering catch can. Tuned by Cunningham Motorsports.
1967 Bolero Red 396 SS/RS Convertible
HAMBO is offline   Reply With Quote
Old 03-29-2018, 07:54 PM   #2
JANNETTYRACING
JANNETTYRACING's Avatar
Originally Posted by HAMBO View Post
Hi everyone,
HAMBO
Hello Hambo, That tube kit is designed specifically for the CAI kit which is the best on the market for this SLP supercharger
It is offered for guys who already had a CAI kit then added an SLP supercharger.
I suggest you consider the full kit seen in the picture priced at 399.00
For 139.00 you get the tube, coupler and clamps no filter no box.
Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 03-29-2018, 11:31 PM   #3
Pro-tuned
Angewendet Ingenieur
Pro-tuned's Avatar
Drives: 14 Camaro ZL1
I had a previous engine set up this way. It was perfect at over 600RWHP until I wanted more and sold it. It also had an excellent JRE tune and was very streetable.
LQ9, Iron Block, Forged internals, 408CI, Jannetty custom cam, TS short block, Whipple, Hardened Jackshaft, PRC 260, 2X3 Dynatech Full Competition, HF Cats, CAI, NW 103, Chee, ID 1300, COPO Breather, MSD, Fore Dual Pump, ultratorque, E85, dual Meth, True Trac, 3:45, 1500hp axle-shafts, DSS CF, BMR, custom Pearl/Candy paint by Jaidah.
Pro-tuned is offline   Reply With Quote
Old 03-30-2018, 11:53 PM   #4
SS PANTHER
SS PANTHER's Avatar
Drives: 2013 SS Supercharged Convertible
You adding a CAI Hambo? I have the tube for mine.
SS PANTHER is offline   Reply With Quote
Old 04-05-2018, 03:38 PM   #5
JackLS1R1
Drives: 10 SS A6 Huron TT
I have this
http://www.camaro5.com/forums/showthread.php?t=516513
2010 2SS RS / A6 and Sunroof / Huron Speed TT / cam/ E85 fuel system / 3200 stall / SBE
JackLS1R1 is offline   Reply With Quote
Old 04-26-2018, 02:20 PM   #6
HAMBO
HAMBO's Avatar
Quick update here, I did buy the tube and it worked with the CAI I had (which happened to not be Cold Air Inductions). Seems like it could fit a handful of CAIs of similar cone size, and where the hole for the MAF sensor isn’t directly attached to the intake itself (rather, is part of the intake tube).
2013 AGM 2SS/RS
