Old 03-30-2018, 02:02 PM   #1
metrogdor22
Drives: 2013 2SS M6
Can I restore NPP exhaust functionality with a tune?
I'm going to say something I never thought I would: My car is too loud. After getting offroad headers and a cam, I need to quiet it down, at least in the mornings. My car is equipped with the factory NPP exhaust, but the previous owner did something to keep them open. The only way I know of to do this is by pulling fuse F8 in the trunk fuse box. I checked today, and that fuse is still there. Did the previous owner do something else to keep it open? Maybe a tune? Can I get it retuned to restore that to factory functionality?
metrogdor22 is offline   Reply With Quote
Old 03-30-2018, 02:11 PM   #2
1911 1LE
Drives: 2015 SW 2SS 1LE
Try pressing the garage door buttons with the car idling and see if it quiets down with one of them. That's how I have mine.G/L
1911 1LE is offline   Reply With Quote
Old 03-30-2018, 02:14 PM   #3
metrogdor22
Drives: 2013 2SS M6
Thanks for the suggestion. No luck. That's how I'd like to have it setup though.
Old 03-30-2018, 02:47 PM   #4
O.F.
O.F.'s Avatar
Drives: 2015 BLK/BLK 2SS/RS MN6
Have you pulled fuse 8 to see if there is any difference?
O.F. is offline   Reply With Quote
Old 03-30-2018, 03:17 PM   #5
larry_g
larry_g's Avatar
Drives: 2014 1SS/1LE
Under normal operation, the flaps will stay open at idle unless you wire a three-position switch to force them closed.
Old 03-30-2018, 03:31 PM   #6
metrogdor22
Drives: 2013 2SS M6
What? I thought they were closed at idle and opened up at 3k RPM. Isn't the purpose to keep it quite when you start it in the morning, or in a neighborhood?
Old 03-30-2018, 03:38 PM   #7
1911 1LE
Order the Forza 3 way controller and program it to the garage buttons
Old 03-30-2018, 03:46 PM   #8
zz430camaro
zz430camaro's Avatar
Drives: 2015 1LE
NPP is OPEN at idle and closes when the vehicle starts to accelerate until around 3500 rpm then it opens again.
zz430camaro is offline   Reply With Quote
Old 03-30-2018, 03:52 PM   #9
JD555
JD555's Avatar
Drives: 2014 2SS RS, 6 sp man
Yep what he said. Open at idle and closes on mine about 15-20 MPH at slow accelerations. Get on it and it opens. Get the Forza 3 way and in the morning you can close the flap and open it when you want or select the factory setting. The only time I close mine is startup in the morning and If I have the backseat down sometimes you can hear drone. You can look in the pipe and see if the flap is closed.
JD555 is offline   Reply With Quote
Old 03-30-2018, 04:13 PM   #10
larry_g
larry_g's Avatar
I wired in my own three position switch following this diagram...
http://www.camaro5.com/forums/showpo...44&postcount=9
Old 03-30-2018, 04:28 PM   #11
xc_SS/RS
Drives: 2010 Camaro SS/RS
Corvette system was designed differently than the Camaro system.
if you want the system to function like the Corvette system then you can run your own vacuum lines and use a C3 Corvette headlight switch to control it all.
2010 2SS/RS
Z/28 intake, NW, FAST 102, speed engineering LT's, some exhaust, ATI -10% pulley, GM flex fuel injectors, DSX flex fuel sensor, MGW shifter, HP Tuners, some suspension work, stickers and a little weight loss. 12.63 @113.53
xc_SS/RS is offline   Reply With Quote
Old 03-30-2018, 11:07 PM   #12
Avenging Orange
Avenging Orange's Avatar
Or add cats....
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 03-31-2018, 04:38 AM   #13
Ashen L99
Ashen L99's Avatar
Drives: Ashen grey, 1SS, L99
Originally Posted by Avenging Orange View Post
Or add cats....
Hell no lol
Roto-fab big gulp, Nick Williams 102mm TB, Kong X-port LSA, Ported 821 heads, BTR stage 4 V2 pd cam, 416 CI bottom end, original block. TSP 2” long tubes, Corsa ZL-1 catback. Nitrous Outlet 102mm plate kit/100 shot JUST IN CASE. NGK BR7EF plugs with Taylor plug wires. DSX flex fuel kit, DSX aux pump, zl1 in tank. deatchwork 1000cc injectors. B&M deep trans pan, stock 6L90 converter, ZL1 diff 3.23 ratio. GM ground effects, T-Rex upper grill, Z/28 Spoiler, Forgestar F14s, 12” subwoofer, and custom paint matched interior.
Ashen L99 is offline   Reply With Quote
Old 03-31-2018, 07:09 AM   #14
camguynj
camguynj's Avatar
Drives: '13 SS/RS LS3 BRM Cammed NPP
Don’t know about a tune controlling the NPP but I’m going to guess no. Couple of other thoughts. Is the fuse good? Check out a Dashlogic OBD2 unit. In addition to displaying PID info onto the DIC, HUD or Mylink screen it also controls NPP operation ( stock, always open, always closed) NO wiring required, you just use the cruise control button like a toggle switch.
camguynj is offline   Reply With Quote
exhaust, loud, muffler, npp, tune
