Old 03-31-2018, 06:45 PM   #1
Reix
Drives: Camaro 2SS '10
Which forged pistons and rods?
Engine: LS3
Transmission: M6
Mods: BTR Stage 4 Cam w/ supporting mods (chain, trunion kit, oil pulp, etc.)
Straight Pipe headers back
Stock headers
Nitrous Outlet wet kit 150 shot
Cracked a piston after cam installation so I’m looking for some suggestions, my machine shop guy said to go with Wiseco pistons, and they are going do a valve job along with forged pistons, bearings, rods, and rings.
Thanks guys.
Reix is offline   Reply With Quote
Old 03-31-2018, 08:30 PM   #2
sinisterlsx510
sinisterlsx510's Avatar
Drives: 14 ss camaro summit white
If u got the keesh oliver billet rods. Lunati billet... even callies rods ..wiesco or diamond!
2014 ss camaro
Stainless works long tubes , rotofab cai , vararam wedge , muffler delete,cat delete ,resonator delete , x pipe
2019 sierra duramax 2500 all terrain x
2001 trans am
Lsx 408 ci rebuild in progress(dead project)
1967 camaro
Sbc 327.
sinisterlsx510 is offline   Reply With Quote
Old 04-01-2018, 05:48 AM   #3
GT Kilr
GT Kilr's Avatar
Drives: 2011 RJT 2SS
I just did Wiseco pistons with the HD wrist pin upgrade, Callies Compstar H beam rods, and ARP main/head studs to go along with those. For comparison, mine is seeing boost from two 62mm turbo's, and I have absolute confidence in it until 18psi or so. My engine guy set it up for 20psi but honestly at that point I still would worry more about the factory cylinder sleeves and core shift, before I would worry about the rods and pistons. I didn't see any point in stronger rods in a factory block scenario. My 2c
GT Kilr is offline   Reply With Quote
Old 04-01-2018, 11:27 AM   #4
Bo White
Bo White's Avatar
CompStar is popular.
Even Eagle and Scat will do well.
I like CP and Mahle pistons.
2015 2SS 1LE Clutch reservoir, Vararam DRX, ported TB, TSP 2" headers, MGW shifter, stage 4 cam and Wilkes 11° 65cc heads
Totalled:
2010 1SS Wilkes Performance/Eagle 416 shortblock, TSP custom valvetrain, PRC 260 heads, Edelbrock Pro Flo 102, th400 swap, 8" PTC 5500 stall= 535/435 at the wheels tuned Gen 3 Performance and Dyno 10.97 @ 124 full weight in 3100 DA CamaroFest X
Old 04-01-2018, 11:34 AM   #5
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
Molnar has a very nice product often over looked..https://molnarrods.com/molnar-connecting-rods-catalog
personally the 3.90 stroke option they have is being give sum consideration for way day the road future possibilities dreamin etc...lol
good luck OP and post pic's of the built...pics FTW! peace
Old 04-04-2018, 08:11 AM   #6
christianchevell
old school chevy rodder
christianchevell's Avatar
Molnar makes many products also others label as theirs...... I went molnar crank and rods and racetec pistons . If your going forged you might as well stroke it and get torque, and that requires a modding for the windage tray or a mast windage tray and modding it, also clearancing for the rods and etc....
Old 04-04-2018, 05:29 PM   #7
Pro-tuned
Angewendet Ingenieur
Pro-tuned's Avatar
Drives: 14 Camaro ZL1
100% agree...
LQ9, Iron Block, Forged internals, 408CI, Jannetty custom cam, TS short block, Whipple, Hardened Jackshaft, PRC 260, 2X3 Dynatech Full Competition, HF Cats, CAI, NW 103, Chee, ID 1300, COPO Breather, MSD, Fore Dual Pump, ultratorque, E85, dual Meth, True Trac, 3:45, 1500hp axle-shafts, DSS CF, BMR, custom Pearl/Candy paint by Jaidah.
Pro-tuned is offline   Reply With Quote
Old 04-05-2018, 09:36 AM   #8
ecreps
Drives: 2014 1LE, 1996 z28
4" stroke in a stock sleeved ls motor is a bad idea imo. Shorter piston compression height coupled with pulling the piston out of the sleeve farther usually results in excessive piston rocking and skirt wear. It works, but is not going to be as long lived as a shorter stroke. Just my .02.
ecreps is offline   Reply With Quote
