Old 04-01-2018, 12:44 AM   #1
TacSac
Drives: 2013 ZL-1
ZL1 agp turbo install/ what accessory drive?
I have a 2013 ZL1 car and im interested in what the turbo guys run for accessory drive. I will be using the lsa long block with factory heads. with ac, with alt, no PS as it is electric.
I want the AGP bottom mount twin kit, with a stock ls3 intake.
Can I install an ss crank pulley without hurting anything ? balance etc.
Do I need SS water pump or drive parts ?
or is is as simple as removing supercharger belt and tensioner and leaving factory stuff there.
TacSac is offline   Reply With Quote
Old 04-01-2018, 01:13 AM   #2
DSMer1
Drives: 14 and 15 SS's
There SS crank pulley is spaced completely different. I would think you would just uninstall the blower ring and associated drive components
Bolt-ons!
DSMer1 is offline   Reply With Quote
Old 04-14-2018, 01:11 AM   #3
CT23
CT23's Avatar
Drives: 13' ZL1 M6
I'm just removing supercharger and tensioner. Most of the way done with the install.
CT23 is offline   Reply With Quote
Old 04-14-2018, 02:27 AM   #4
DSMer1
I hope that's a solid wood door that cradle is sitting on!
Bolt-ons!
Old 04-14-2018, 04:48 AM   #5
CT23
CT23's Avatar
Drives: 13' ZL1 M6
Ha, it is. But it's only lightly resting on the door. Still have the cherry picker holding most of the weight.
Old 04-14-2018, 12:39 PM   #6
white1LE
white1LE's Avatar
Drives: 2013 Camaro ZL1
You will need to run a C6 Corvette balancer or a ZL1 ATI balancer for the ZL1 (recommended) without the purchase of the SC 3rd ring.
13 ZL1 A6
LSX 427 with AGP Twin Turbos, E85 and Flex Fuel. Built and tuned by ADM Performance
1000rwhp
white1LE is offline   Reply With Quote
Old 04-14-2018, 09:07 PM   #7
Moreair1
Moreair1's Avatar
Drives: 2011 ss convertible
I would send Kevin with agp a message he will answer all your questions
Cai intake and a few other mods😎
Moreair1 is offline   Reply With Quote
Old 04-15-2018, 12:03 PM   #8
robrocketanski
robrocketanski's Avatar
Drives: ZL1 Convertible Auto
I am using my ATI without the blower pulley and leaving the rest stock ZL1 except leaving off the blower tensioner.
LS3 intake and throttle body, Huron Speed Products twin turbo with 6265 oil less turbos, and 3" header back, JRE smooth cam, ID1300, Fore dual 450lph pumps with MSD voltage booster, A6, 305/45/17 MT Street R
robrocketanski is offline   Reply With Quote
