Old 04-02-2018, 11:29 PM   #1
elbambino19
Drives: 2015 Chevrolet Camaro 2SS
Passenger Door Jammed Shut - Need Help
The passenger door on my 15" Camaro SS stayed jammed shut after closing it one day. The door panel is off and the outside handle as well, I have tried pulling the lever down that is on the lock door actuator and the door still wont open. It does sound like it unlocks and locks with both push button and remote but door still wont budge. I know it may need a new door lock actuator, I just need ideas on how to get it open or fixed if possible without purchasing a new actuator. Also want to avoid any damages to the car if possible. Any help is appreciated thanks!
elbambino19 is offline   Reply With Quote
Old 04-03-2018, 07:05 AM   #2
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
The door has to be open to access the screws that hold the actuator.
If the door latch rod is connected to the outside handle at one end and the actuator at the other, the door should open. Why did yo take off the handle?
Rock-It Man is offline   Reply With Quote
Old 04-03-2018, 01:16 PM   #3
elbambino19
The handle and trim was removed to wrap the vehicle completely. Everything is connected how it should be. The door stays jammed still, I also understand the door needs to be opened to remove the torx screws but as stated above I can't since the door is jammed shut... What I want to know is there a way to get it open I haven't tried yet? Do I have to break the actuator apart from the inside? and drill out the bolts? or any other easier way of doing this I hope?
Old 04-03-2018, 01:55 PM   #4
Rock-It Man
Well, I'm not going to remove my handle or inside trim to test this, but again, if the latch rod is connected properly at both ends, the door should open.
There is an adjustment on the latch rod that you can check. On the actuator end, the rod is held by a retaining clip. Open the clip. Let the rod hang down, making sure the outside door handle is in the closed position and then close the clip again, clamping the threaded end of the rod.
It's also possible that this rod got bent and is binding up.
Old 04-03-2018, 02:12 PM   #5
elbambino19
I can physically see the inside of the door and actuator, I have tried removing the rod and just pulling down the lever and it just doesnt budge 🤷*♂️
Old 04-03-2018, 02:24 PM   #6
Rock-It Man
Doesn't the lever go UP to open the door?
Old 04-03-2018, 02:27 PM   #7
elbambino19
No, it goes down on this one.
Old 04-03-2018, 02:36 PM   #8
Rock-It Man
Since the handle end of the rod is a hook, I don't see how the rod would push down on the lever to open the latch. It would be like pushing on a rope.
So I suggest again that you open the clamp, let the rod hang free and then close the clamp. Then work the outside handle and see what happens.
Old 04-03-2018, 02:47 PM   #9
elbambino19
No, it pushes down. Look up the part on rockauto to see for yourself.
Dorman P# 931315
Old 04-03-2018, 04:42 PM   #10
Rock-It Man
Dorman P# 931315
I can't tell anything from that photo at rockauto. But the shop manual shows that the door handle end of the rod is a hook. Maybe the hook got jammed or the rod got bent.
The shop manual process for adjusting the rod is what I said: release the clamp, let the rod hand freely, close the clamp.
The rod should be free so that it can easily be unhooked from the door handle mechanism. If it's not, that could be part of your problem.
Old 04-04-2018, 08:28 AM   #11
Rock-It Man
Did you figure it out?
Seems like there ought to be a way to unlatch the door manually without doing anything destructive.
