04-04-2018, 09:20 PM | #1 |
Drives: Savitar; The 500rwhp N/A Monster! Join Date: Aug 2016
Lowering Spring Question
Hello! I was hoping some of you who are more knowledgeable in the suspension area could help me with something. I plan on buying z28 reps for my car which will be 20x10 23mm up front and 20x11 43mm in the rear. I plan on running a 275/40/20 tire in the front and a 315/35/20 in the rear.
A buddy of mine offered me a great deal on a set of BMR 1.4" lowering springs for the front and back. I would like to buy these from him but am not completely sure it will work with my future tire/wheel setup. Could someone who knows more chime in? I did a few searches but couldn't find an answer that pertained specifically to my information, sorry if I missed it if this has already been covered. Thanks a bunch!
*SOLD*504HP/433TQ | Night Fury cammed Cold Air Inductions intake Bo White ported TB Speed Engineering 1 7/8 longtubes NPP catback QTP low profile cutouts Powerbond 25% UDP 3.73 gears JRE scoop ZL1 grille R1 Concepts drilled/slotted rotors built/tuned by Weapon X Motorsports
04-04-2018, 10:33 PM | #2 |
Drives: 2014 1le 1SS CRMT Join Date: Apr 2014
I’d do a 285/35/20 & 315/30/20
04-11-2018, 03:06 PM | #3 |
Drives: 2015 SS/A6 Join Date: Feb 2016
I know for sure 5th Gens ZL1s run 315s on a 1.4 drop...I mean if the tub is the same and not different I don't see a reason why it should be a issue.
2015 Camaro SS/A6--Roxy MOD'S
*Rear Muffler Delete *VMAX Throttle Body *Speed-Engineering Headers / No Cats *Catted Magnaflow X-Pipe *BMR Toe Rods *BMR Xtreme Ant-Roll Kit *BMR Trailing Arms *CAI Cold Air Intake *TUNED BY JAY @ KRAFTSWORKS EXCELL |
04-11-2018, 03:47 PM | #4 |
Instagram: Sangstah
I think you should be fine with that setup
2019 SS 1LE - "CaSSandra" 2014 SS - "AleSSandra - Sold" 94 Z28 - Sold Follow the build https://www.camaro6.com/forums/showthread.php?t=612717 |
04-19-2018, 11:09 AM | #5 |
Started#gottalovethatblue
If you go lower than 1" drop you do run risk of rubbing on large bumps. My friend has 1.25" lowering springs and is running 315 rears and does occasionally hear the tires rub slightly when he hits a large bump. Based off of recommendations from a wheel distributor I went with the 1" only because like you I plan on going with 315 rears eventually.
04-19-2018, 02:14 PM | #6 |
Drives: 2011 Camaro 2SS Join Date: May 2016
I had BMR 1.25' in the rear and BMR 1.4 in the front with the Z28 reps, that set up looked better than any other camaro I've seen (just my opinion though)
2010 Camaro 2SS-Mods: Nightfury cam, CNC ported LS3 heads, CNC ported TB, Ported Intake, RX Catch Can, MGW Short Throw Shifter, Mantic 9000 Clutch, TSP 1 7/8 headers, catless NPP, BMR trailing arms, MMR Z/28 Reps 20" gloss black. SOLD
2011 Red Jewel Tintcoat 2SS-Mods: Edlebrock E Force S/C w/ 3" pulley swap,Texas Speed roller Boost Cam 227/235, 641"/649", 114 LSA, PRC Ported Heads, Ported TB,ARH 1 7/8 headers, McLeod RST twin disk 1000 hp clutch, ZL1 Fuel Pump, 620whp |
04-19-2018, 02:48 PM | #7 |
Instagram: Sangstah
^damn I'm running 1.25 all around but may go 1.4 up front now after seeing yours!
04-19-2018, 03:19 PM | #8 |
Yeah, it was alot more aggressive with the front lower
04-20-2018, 01:42 PM | #9 | |
Drives: 2019 ZL1 1LE M6 Join Date: Nov 2013
I have that tire and wheel set-up w/ FR ZL1's 1.25 BMR front and rear No rub / no issues Thanks, Cowpunk Last edited by cowpunk; 04-20-2018 at 01:43 PM. Reason: add info |
