![]() Drives: C5 LS3, C5 LS1, ZL1 LSA Join Date: Feb 2018
NPP catback for sale
sold.
![]() Last edited by MrLSX; 05-26-2018 at 07:44 PM. Reason: sold |
![]() Drives: 2013 Camaro Convertible RS 2LT Join Date: Mar 2018
Any 5th gen? How about a V6? Would it require any modification for install and operation
Yes, bolts up to a V6 with no issue. The only "modification" needed would be room for the quad tips. But thats easy, you could just replace the valence.
Yes I kind of figured that part. But specifically
are the pipe diameters the same? are the hanger locations and pipe, muffler routing and locations the same Any welding required Any programming or chips or... required to make the vales open like they should at correct RPM Finally -will it sound good with a V6 |
#5 | |
To answer your questions.. 1. No, my diameter is full 3 inch. 2. Hanger locations and everything are the exact same, no welding or any modification needed. 3. No programming or anything needed, valves are open. 4. One of my buddies has a V6 with the same setup. Sounds much better than your stock exhaust.
#6 |
Thanks for the info. I am going to look around a bit more.
#7 |
Hmm wasn't expecting that after answering everything...
#8 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Savitar; The 500rwhp N/A Monster! Join Date: Aug 2016
Almost positive the NPP is 2.5 for both the ZL1 and 1LE, 2.75 on the Z28.
*SOLD*504HP/433TQ | Night Fury cammed Cold Air Inductions intake Bo White ported TB Speed Engineering 1 7/8 longtubes NPP catback QTP low profile cutouts Powerbond 25% UDP 3.73 gears JRE scoop ZL1 grille R1 Concepts drilled/slotted rotors built/tuned by Weapon X Motorsports
#9 |
![]() Drives: 2011 Camaro 2SS Join Date: May 2016
NPP does not come with 3 in. diameter
2010 Camaro 2SS-Mods: Nightfury cam, CNC ported LS3 heads, CNC ported TB, Ported Intake, RX Catch Can, MGW Short Throw Shifter, Mantic 9000 Clutch, TSP 1 7/8 headers, catless NPP, BMR trailing arms, MMR Z/28 Reps 20" gloss black. SOLD
2011 Red Jewel Tintcoat 2SS-Mods: Edlebrock E Force S/C w/ 3" pulley swap,Texas Speed roller Boost Cam 227/235, 641"/649", 114 LSA, PRC Ported Heads, Ported TB,ARH 1 7/8 headers, McLeod RST twin disk 1000 hp clutch, ZL1 Fuel Pump, 620whp |
#10 | |
My apologies. I looked it up and you're right. A fellow Camaro buddy of mine told me it was 3 inch.
#11 |
Bump. Lowered price.
#12 |
Questions are what smart people use to make good decisions. "3 inch"
#13 | |
2.5 or 3 inch will not make an ounce of difference for your V6.
#14 |
Bump.
