Old 04-05-2018, 08:32 AM   #1
darik1fine
Drives: 2011 camaro ss
Exclamation HELP WITH CAM FOR DAILY DRIVER
ok guys I am sure this question has been beaten to death but i have a 2011 camaro ss 6.2l L99 in it. I currently have kooks LT headers, corsa catless exhaust, CAI, and its tuned. I want to put a cam in it but I am pretty lost when it comes to these. I want a cam that gives me enough hp to justify buying it but its my daily driver so i dont want to go so big that i have to put a stall converter on it or when driving at low speeds it starts bucking on me. so how what size and what brand cam should i go with for my daily driver? also what all parts would i need and whats the best kit out there. THANKS IN ADVANCE GUYS!!
darik1fine is offline   Reply With Quote
Old 04-05-2018, 08:51 AM   #2
ozzy1le
ozzy1le's Avatar
Drives: 2015 camaro 1le
Talk to gpi. They have some great cams. Gwatney performance
ozzy1le is offline   Reply With Quote
Old 04-05-2018, 08:55 AM   #3
TheWood
Drives: 2013 SS
2nd for GPI.
2011 L99
CAI, SE LTs, 3.91 gears
2013 L99
3.91 gears, OBX LT, CAI, NO 100 shot, BMR Toe Rods, trailing arms. SOLD
TheWood is offline   Reply With Quote
Old 04-05-2018, 08:56 AM   #4
RS111341
RS111341's Avatar
Drives: 2011 SS IOM auto
Texas-Speed VVT 1.2 if you’re doing the dod/afm delete. They make an AFM cam but the gains aren’t as good
RS111341 is offline   Reply With Quote
Old 04-05-2018, 09:48 AM   #5
hrpiii
AKA "Beefcake"
hrpiii's Avatar
Drives: 2023 ZL1 Sharkskin
Check out Raymonds Performance here in Indy. They work on a lot of Camaro/Vettes and support a couple race teams. They have done a lot of work on my Camaro and super satisfied. They will treat you very well and take care of your car.
Old 04-05-2018, 09:57 AM   #6
Avenging Orange
Avenging Orange's Avatar
Guess it all depends on what you consider "justifiable" gains. I have done big and small. I learned it was (for me) better to stay small and hunt the best tq curve. Where it starts, where it ends and how flat.
Do some reading....you'll find big cam posts by the thousands...but look for the few that have stuck with the smaller ones. Good luck.
https://youtu.be/9JD9it6SmB8
https://youtu.be/xmelTlEzI34
Old 04-05-2018, 11:32 AM   #7
Hixson
Hixson's Avatar
Drives: 2015 Camaro 1SS L99
Look for my build thread as I will be updating it throughout the weekend. I have a 2015 L99 1SS and elected to go with the GPI VVT SS1 cam kit - as I wanted to daily drive and not worry about longevity. I will be posting before Vids, during pictures, and hopefully after videos so long as we dont mess anything up. My recommendation though would be to go with GPI and do the SS1 if you want stock torque convertor or SS2 if youre buying a stall. Aaron, Dan, and Ryan at GPI have been fantastic so 2 thumbs up from me so far.
Hixson is offline   Reply With Quote
Old 04-05-2018, 11:46 AM   #8
LCPLPunk
USA-1
LCPLPunk's Avatar
Drives: 2010 Camaro SS L99
If not going with an aftermarket converter, Gpi SS1. If you are, then Gpi SS3.
"A Camaro in the garage is safe, but that's not what Camaros are built for..."
R2C CAI / Apex Scoop / VMAX Ported TB / Speed Engineering LTHs / X-pipe / GPI port/rod-mod intake manifold / Circle D 3200 278mm Converter / 3.91 gears / DynoSteve tuned / 1LE Shocks/Struts/Toe Links / ZL1 Rear Sway Bar / Z/28 Trailing arms / Prothane Radius Arm & Subframe Bushings / BMR UCA Bracket, Steering rack bushing / B&M Tranny Cooler / RX Catch Can / Jannetty Tranny Dipstick / 2012+ Heater Hose / 2013+ Rearview Mirror / Fuel rail flip / Drake shifter / Oil Cooler Delete
LCPLPunk is offline   Reply With Quote
Old 04-05-2018, 12:37 PM   #9
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
so I waited and hoped the obvious would be asked...who tuned the car? are you going to use the same tuner? what does your tuner say? lulz...once this has been worked out and your budget determined(you do have a budget right?) lol...anyway you can then decide if an off the shelf vs custom grind will suite your needs...then it's just a matter of price matchin out the rest of the kit..
now I use and will always use dynoSteve at RDP for my remote tunes(don't need no stinkin dyno...lulz..prefer real word 1/4 times) and they also sell parts to C5 peeps at a discount..free s/h etc...
so do your self a favor and give them a holler...https://www.rdpstore.com/
l8tr
FYI - just so it come as no surprise..your L99 is gonna cost more to cam esp if you decide to VVT delete....just sayin....good luck!
lulz go delete so you can pull and have the heads ported...wahoo!
5th gen camaro, cam kit, mods
