Old 04-05-2018, 04:00 PM   #1
metrogdor22
Drives: 2013 2SS M6
Is my cam pushing it?
I had a custom ground cam recently installed and the specs are 226/240 .637"/.620" 113+4. I wanted something relatively mild to avoid any problems, and I'm wondering if that cam is pushing what I should be running on stock rockers and lifters. The shop that spec'd the cam and did the install is a reputable local shop that does almost exclusively LS engines.
Compare it to a BTR Stage IV for example (233/250 .618"/.596" 113+5) - it has a bit less duration but a lot more lift. BTR also has this disclaimer for that cam: "Lift approaching .650" or more while using stock 15 degree rocker arms with too much open spring pressure can damage valve tips long term. We recommend maximum lift of .630" and maximum open pressure of 400 lbs when using stock rocker arms." The shop also installed BTR .660" platinum springs, which hit that 400lb maximum.
The car drives fine; idles at 750 RPM with only a little surging and only starts to buck below 1500 RPM. Any thoughts from experienced cam guys and gals?
2013 2SS M6 - Custom cam w/ miscellaneous valvetrain upgrades, ported heads, longtubes, CAI, CTS-VR lifters, Forza NPP exhaust controller - 500hp/460tq
metrogdor22 is offline   Reply With Quote
Old 04-05-2018, 04:33 PM   #2
ecreps
Drives: 2014 1LE, 1996 z28
It's on the bigger side, but I think you're fine. Do you know what lobes it uses?
lots of LS guys running larger cams in stroker motors with more duration and lift on stock rockers. It probably isn't 100% ideal, but it seems to work ok.
ecreps is offline   Reply With Quote
Old 04-05-2018, 05:41 PM   #3
frankwjr
frankwjr's Avatar
Drives: 2010 SS 2SS M6
I recommend upgrading the trunnion's to one of the brass style...other than that should be good.
who spec'd and ground the cam? and who did the tune? peace
Old 04-05-2018, 06:27 PM   #4
Dbunch9
Drives: 2010 Camaro 2SS
You would poop your pants if you saw the cam I'm putting in next week lol
Dbunch9 is offline   Reply With Quote
Old 04-05-2018, 07:53 PM   #5
sixty9fordkiller
Donkey Dick Cam Camaro
sixty9fordkiller's Avatar
Drives: 2010 2SS/RS LS3 M6
also, the BTR Stage 4 cam specs you referenced will require flycutting on the exhaust valve side of the stock LS3 pistons if the exhaust duration on the cam is 250 and you're using stock LS3 heads
Bone Stock
sixty9fordkiller is offline   Reply With Quote
Old 04-05-2018, 07:59 PM   #6
sixty9fordkiller
LMAO!!!!!
Let me guess........
Cam Motion LLSR?
Bone Stock
Old 04-05-2018, 09:12 PM   #7
Rich2010
Drives: 2010 Cyber Gray LS3 SS/RS
Negative on that, I’m running it now. Stock untouched bottom end, with BTR springs, pushrods, and stock trunions.
2010 Cyber Gray LS3-BTR stage 4-480/428 RXT and 3.91’s
Rich2010 is offline   Reply With Quote
Old 04-05-2018, 09:14 PM   #8
sixty9fordkiller
What was the ptv clearance?
Sent from my SM-G965U using Tapatalk
Bone Stock
Old 04-06-2018, 09:02 AM   #9
acammer
GPI Sales Consultant
acammer's Avatar
Drives: 2011 Camaro 2SS SGM
Likewise - there are definitely off the shelf grinds that offer even more lift and duration on a tighter LSA that still have acceptable PTV clearance. The GPI stick going in my car this month has more lift that OPs cam, and more duration than the BTR STG4 on a tighter LSA than either of them. Still maintains acceptable PTV clearance on stock heads without the need to flycut.
It's what I would consider a "max effort" without pulling the heads kind of cam that doesn't absolutely shred the valve-train. GPI has a proprietary cam lobe that is designed to work with the stock lifters/rockers and BTR .660 Platinum springs. So - all that said to really say that the cam the OP has isn't a monster stick, and shouldn't be a major concern for tearing up the valve-train - just keep an eye on the springs.
Got a question about a GPI product? Feel free to shoot me a message!
acammer is offline   Reply With Quote
Old 04-06-2018, 09:15 AM   #10
lazerlemonta
lazerlemonta's Avatar
Drives: 2010 C6 1LT
Roller Rockers are your friends....................
2010 C6 JET STREAM BLUE
BOLT ONS TO THE EXTREME, GPI 281cc HEADS, Darth_V8r SPEC CAM, FAST 102 INTAKE, CRANK SCRAPER, QUARTER MASTER 7.25" CLUTCH, RPM 3.90 STAGE II DIF, Z51 Gear Set AND E85
Best ET 10.58 @ 131.8 stock heads and stock cam 453/445 SAE
10.62@134.82 GPI 281CC Heads, SS4 Cam and X1 Intake
Best 1/8 6.80@105.75
Best MPH 134.82
lazerlemonta is offline   Reply With Quote
Old 04-06-2018, 09:18 AM   #11
metrogdor22
Drives: 2013 2SS M6
Any recommendations on brands?
Old 04-06-2018, 09:46 AM   #12
lazerlemonta
Drives: 2010 C6 1LT
i have had good luck with YellaTerra, harland sharp and crower. A non adjustable would be fine for your set up and stick with a stock 1.7 ratio. I use 1.85s and when and if i do a cam i will reduce my lift to accommodate them.
Best MPH 134.82
Old 04-06-2018, 10:57 AM   #13
Rich2010
Had a local, very reputable shop install it so I don’t know. There’s enough that when I’ve bounced the 7000rpm limiter on a few occasions there wasn’t an issue 😬.
Old 04-06-2018, 11:54 AM   #14
Punisher_ATX
Drives: 2010 SS
Low lash solid on Stock Rockers here. Seems okay to me haha
Punisher_ATX is offline   Reply With Quote
cam, duration, high, lift, spec
