Old 04-06-2018, 10:05 AM   #1
thebluecamaross
thebluecamaross's Avatar
Drives: 2010 Camaro 2SS/RS ABM
Z/28-Common Problems?
Hello guys!
I'm looking into purchasing a 2015 Z/28. It would obviously have to be used, I will be looking at cars that have between 0- 18,000 miles.
I just wanted to know from Z/28 owners what are important things to look for and what are known problems for Z/28 long term. I plan on keeping this car till I croak. (I'm 22).
Little things like pad replacements, oil changes, etc will be done by me. However more tedious work would have to be done by professionals.
I plan on also purchasing a daily since I want to refrain from putting extensive miles and reduce risks in general.
I don't plan on tracking the car more than 4 times a year either so I will not be pushing it that often (do not ask then why buy a z28).
I do plan on modifying the car buy putting in FBO.
Thanks again guys,
Gabe.
thebluecamaross is offline   Reply With Quote
Old 04-06-2018, 10:43 AM   #2
1970judge
Drives: 2015 Z/28, 2007 HHR
Common issues with Z/28? With all sincerity, there really isn't any 'common' things to look for. Check the rotors/pads for abuse, check for regular maintenance (as you would with any car). I guess the only thing that sticks out in my mind is the paint on the fuel rail covers that say "Camaro" and "427" peels...thats about all I can think of. The 5th gen was 'nearly' free of defects by 2015. I bought mine sight unseen, shipped it form Houston, TX to Michigan..without worry.
1970judge is offline   Reply With Quote
Old 04-06-2018, 11:36 AM   #3
2SSRS@Gen5diy
2SSRS@Gen5diy's Avatar
+1 car is a rock star, 4+ years 8500 mi and a lot of track days.
Old 04-06-2018, 11:53 AM   #4
Supercup
Life Is Short Enjoy It!
Supercup's Avatar
Drives: Former Owner 15 Z/28 #934
The most common problem on the Z/28 is there are not problems.
Mine has been rock solid as well - not one issue to date.
Supercup is offline   Reply With Quote
Old 04-06-2018, 01:11 PM   #5
Gbland60
Gbland60's Avatar
Drives: 2015 z28 Black w/ac #645
Just bear in mind you will hear all kinds of noises from the rear end to the transmission but all this is normal because of no insulation
Gbland60 is offline   Reply With Quote
Old 04-06-2018, 01:19 PM   #6
1970judge
This is also true, lots of noise transfer in these cars, all normal.
Old 04-06-2018, 01:35 PM   #7
MrRaZ28
@MrRaZ28
MrRaZ28's Avatar
Drives: 2014 Z28 #80
If you aren't tracking exclusively, make sure you get a good set of tires that aren't Trofeos. It seems most dealers install Bridgestone S-04's. Try to steer away from that only because they are a harder compound and don't last that long. I 10000000% vouch for the Conti Extreme Contact Sports, as does my local track. Love these tires.
If you do not have access to a lift, you will need the long set of race ramps, as well as the extensions to get the car in the the air so you can work on it. Definitely put the skipshift eliminator in.
You have to be urgently, extra specially careful when removing the wheels so that they do not catch on the rotors when you want to rotate/swap pads etc. Also, make sure you are familiar with the costs. OEM pads and rotors are extremely pricey. If you rarely track, you won't have to worry about the rotors as much as they should last a VERY long time, but pads can get up there for a set.
100% truth on the peeling paint on the covers. I just took them off as they retain heat. I have debated getting them repainted and cutting slots and adding mesh so that heat can escape.
Other than that, you will just need to get used to the rear end noise at low speed, like everyone else says. It still bothers me every now and then, but it is what it is. Best car I have ever owned, hands down. Also the safest car I have ever had. I have never once felt out of control, even in pouring rain. I have tried, and failed, to get the wheels to lock up in PTF 5 on wet road, with puddles and couldn't do it.
Also, don't worry about the mileage AS much. Mine had 43k on the clock when I bought it, and I have put over 4k on it now since October. Paid $36k for it. If you are concerned about chips, scratches etc.. just know that, no matter what you do, the track is going to ruin that ideal lol.
MrRaZ28 is offline   Reply With Quote
Old 04-10-2018, 09:42 AM   #8
thebluecamaross
Chevy2tehBone, thank you for that insightful reply. I appreciate it.
Drive safely and I hope to join the z28 life very soon.
Old 04-10-2018, 02:31 PM   #9
rcandiloro
rcandiloro's Avatar
Drives: 2018 ZLE
I haven't read or heard about any "common" problems with the Z/28. I have 11000 miles on mine and it has never skipped a beat.......just a rock solid car top to bottom......and the MOST FUN car you'll ever drive!
rcandiloro is offline   Reply With Quote
Old 04-10-2018, 03:34 PM   #10
shibbs
Captain Gingerbeard
shibbs's Avatar
Drives: 2012 IOM RS/SS 6MT
Wasn't there a problem with the valves on some of the 7.0L?
Custom ordered 2012 6MT RS/SS on 11/25/2011. Picked up 01/31/12.
Pedders Coilovers, BMR trailing arms and toe-links, Prothane solid poly subframe bushings, JDP Motorsports rear upper control arm bushings, Texas Speed long-tube headers with 2" primaries, modified fully 3" Magnaflow competition catback. CAI cold-air intake. DBA rotors, Hawk pads.
'Hellcat' sounds like some kinda 15 year old furry with liek "I'm a blue fox with wings and magical kawaii powers" kind of sh*t.
shibbs is offline   Reply With Quote
Old 04-10-2018, 05:07 PM   #11
zman1969
zman1969's Avatar
Drives: 1969 R/S Z28 302 m20 Endura
I'm pretty sure the General has that fixed, that was 10 years go on LS7s
1969 RS Z/28 302
1969 Firebird LS6-6 speed TA clone
2015 Zl1
zman1969 is offline   Reply With Quote
Old 04-10-2018, 05:21 PM   #12
4 FN 27
Drives: 2015 Z28
Maybe not...they made me whole...and I am a happy loyal GM Customer...
4 FN 27 is offline   Reply With Quote
Old 04-10-2018, 05:43 PM   #13
Stormcloak
slower than you
Stormcloak's Avatar
Drives: 2012 C6 Z06
LS7's have widely documented valve / valve guide issues. How many Z's are affected by this, I'm not sure, but it was an issue for Z06's for a while.
Only other 'problem' is that I don't have one in my garage
Stormcloak is offline   Reply With Quote
Old 04-10-2018, 05:53 PM   #14
nmarklowitz
Drives: 2015 Z/28 Black #371
This is along the lines of this topic.
I've been noticing what sounds like valve tick or maybe lifters in that 2-3k rpm range. Is that normal? I called my local Chev dealer and the service advisor said that sounds normal for the car but I'm skeptical. Any suggestions?
nmarklowitz is offline   Reply With Quote
advice, camaro, usedcars, z28
